Author Topic: FITTING OF OSIR VENT BOOST GAUGE  (Read 3310 times)
Kam88
« on: April 11, 2015, 11:27:42 pm »
I have just hold of OSIR vent boost gauge there is a positive and negative that connects to the light switch if i am correct? and also little hose that needs to be connected somewhere under the bonnet now the help i need is:
1. How to remove the vent without damaging it ?
2. Where do i connect the little hose to ?? i also have a forge recirculating dump valve if that at all makes a difference any help be great?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: FITTING OF OSIR VENT BOOST GAUGE
« Reply #1 on: April 12, 2015, 01:22:59 am »
1. Trim removal tool - very easy
2. Connect it to your diverted valve and hey presto  :smiley:
Kam88
« Reply #2 on: April 12, 2015, 10:19:09 am »
Don't have DIVERTER valve any more got dump valve with two hoses that come out of it which one do I use lol also its mk5 ed30
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: April 12, 2015, 03:35:43 pm »
Have you the little adapters that screw into the side of the valve? If you do use the one with the smaller hole for boost gauge
And it's still a diverted valve, tfsi's don't dump boost, think yours is a BOV?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #4 on: April 12, 2015, 04:12:23 pm »
what he says ^^^
Show us a picture of your dv fitted to your engine bay, we could maybe direct you better.
The boost pipe needs run in through a rubber gromet, to connect onto the gauge.
Silver is the way !
Kam88
« Reply #5 on: April 12, 2015, 05:36:52 pm »
ill take a pic later on and upload it so gives better idea of what it looks like as i am confused lol
Kam88
« Reply #6 on: April 12, 2015, 06:40:40 pm »
some pics if you can make it out ? and give me a hand ?
  • -Receive: 427
« Reply #7 on: April 12, 2015, 07:09:45 pm »
Attach it to the bottom of the hose/pipe coming from the PCV (the corrugated looking one) via a boost fitting kit.
Pic of mine below, I have 2 feeds coming off it via the multi tap. Check my Build thread for link to Forge boost fitting kit, page 1. Also cheap one sare available from AwesomeGTI or nice flash Billet Alu ones from 42 Draft Designs.
Kam88
« Reply #8 on: April 12, 2015, 08:08:47 pm »
thanks for the help any chance getting a close up picture of it if you could please ?
  • -Receive: 427
« Reply #9 on: April 12, 2015, 09:09:50 pm »
Not mine, a Forge Boost Fitting kit.....
Kam88
« Reply #10 on: April 12, 2015, 10:19:33 pm »
cheers mate looking at that i already have that in my box of bits so now i know what it does and where it goes i will fit it  :signLOL:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #11 on: April 12, 2015, 10:26:54 pm »
There maybe a smaller fitting for the boost gauge if i remember correctly and smaller hose...
Silver is the way !
Kam88
« Reply #12 on: April 12, 2015, 10:51:40 pm »
looking at the bits i have the hose the piece that goes onto the pcv and all the bits just being a wolly really i though what the hell them bits are for  :signLOL:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #13 on: April 13, 2015, 01:00:39 am »
Keep us updated !  :happy2:
Silver is the way !
