Author Topic: Oil Pick up Inspection/Replacement/Cleaning  (Read 20742 times)
Re: Oil Pick up Inspection/Replacement/Cleaning
« Reply #30 on: May 15, 2015, 09:53:12 am »
Oops. Sorry, I missed that bit.  :signLOL:
Neodymium magnet? And that works well yeah?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #31 on: May 15, 2015, 10:41:36 am »
I bought it from opie oils
http://www.opieoils.co.uk/p-83967-gold-plug-ap08-magnetic-oil-drain-sump-plug-for-volkswagen-vehicles-ap-08.aspx
Anyone know the torque for the bolt holding the pickup pipe??
05 | Tornado Red | DSG
« Reply #32 on: May 15, 2015, 10:47:38 am »
Id just go for tight. Cant imagine its that critical, as its not subject to any great force.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #33 on: May 15, 2015, 01:38:18 pm »
Magnetic sump plug installed.
New pickup pipe in.
My arms were a bit numb after 6 test fits of the sump. I managed to get a thinner line as i went on.
Sump is in bolts torque to 15nm??
When my arms recover i will finish it off.
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
« Reply #34 on: May 15, 2015, 01:43:42 pm »
lovely  :happy2:
Touran TFSI Quattro | stage 2+ BHZ | UK's first
« Reply #35 on: May 15, 2015, 01:44:59 pm »
Just bought some  15x5mm neodymium magnets to make a mag. sump plug... see if it works.  :smiley:
Offline olethalb
  • -Receive: 31
« Reply #36 on: May 15, 2015, 02:02:29 pm »
Did you move your boost pipe clip @dazza or is it loose?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #37 on: May 15, 2015, 02:11:01 pm »
The boost pipe clip is disconnected and i used a bungee to keep the pipe out of the way.
Offline jonvr6
« Reply #38 on: May 15, 2015, 03:18:28 pm »
All good info cheers for the share
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #39 on: May 15, 2015, 05:31:37 pm »
Went for a quick spin. No leaks at the moment.
Thanks for all your help guys. Onto the cam belt now.
« Reply #40 on: May 16, 2015, 11:58:02 am »
Ive had the ECS mag plug fitted for some time.  Maybe lining the whole of the bottom of the sump with neodymiun magnets will do a good job haha
« Reply #41 on: May 16, 2015, 12:01:29 pm »
Does the ECS one pick up much stuff??
« Reply #42 on: May 16, 2015, 12:45:39 pm »
Made one. Cost about 3 quid  :smiley:
« Reply #43 on: May 16, 2015, 02:19:32 pm »
A miniscule amount.  I will try to remember to get a picture nexto oil change in October
Offline v4rley
  • -Receive: 104
« Reply #44 on: May 16, 2015, 08:05:16 pm »
Seems a good idea but won't the magnetism pass through to the sump ? Where as the other plugs are insulated against the internal magnet. Will be interesting to see results
