Author Topic: Wheel repair advice please  (Read 2464 times)
Offline longbelly
« on: May 25, 2015, 01:26:31 am »
I have been advised by VW at the latest EVC that one of my alloys has had a weld repair and they are advising a replacement. There was nothing mentioned on the first EVC in March. I have only owned the car since March and unsure what to do. I am contemplating either sourcing a replacement, getting the repair professionally checked somehow or just leaving it? Any advice gratefully received. The alloys are 18" Monza 2.
« Last Edit: May 25, 2015, 01:32:19 am by longbelly »
dansmith180
Re: Wheel repair advice please
« Reply #1 on: May 25, 2015, 01:38:25 am »
Not sure where you'd go but I'd have it checked before buying a new one, if the wheel is holding air and balanced properly then its not an imenent issue, as long as it's been done properly then it should be fine.
Offline longbelly
« Reply #2 on: May 25, 2015, 01:52:51 am »
It appears to be holding air and not noticed any imbalance/wheel wobble. Just concerned but seems odd that one VW tech picked it up but the other one didn't :@
dansmith180
« Reply #3 on: May 25, 2015, 01:57:51 am »
Yeah unless its a recall I don't take my car to VW. They just want you to pay for a new wheel, there's plenty of cars out there that have had wheel repairs.
Offline longbelly
« Reply #4 on: May 25, 2015, 02:15:58 am »
That thought did occur to me except they don't supply that model of wheel anymore so no gain for them. Having done some searching I'm aware there's plenty been repaired but just wanting to check it's not a bodge job!
dansmith180
« Reply #5 on: May 25, 2015, 02:31:38 am »
Yeah that's understandable, maybe try a reputable tyre fitters/ wheel refirbishers in your area they should be able to check it over
Offline longbelly
« Reply #6 on: May 25, 2015, 02:32:49 am »
Cheers matey
dansmith180
« Reply #7 on: May 25, 2015, 03:22:48 am »
Offline Matthewsimone
  • -Receive: 39
« Reply #8 on: May 25, 2015, 07:52:01 am »
One of my rears has had a hell of a repair after the original owner hit a chunk of breeze block on a dark 60mph road when the car was only around a year old
The wheel was profesionally welded/repaired and still perfect 6 years later
My very reputable tyre fitter said it's fine
Think it was F1 alloys over in Cheshire that did the repair
Looks like a aliens hand inside my wheel  :jumpmove:
Offline Nino
« Reply #9 on: May 25, 2015, 08:44:09 am »
Don't forget VW are stupidly fussy and will say anything to scare you. They told me all sorts then when i went to see someone i can trust to which i was then told the areas vw pointed out are fine and that there is at least 2-4 years left before they need replacing.
If it hold air and no wheel wobble then whats the issue?
Offline longbelly
« Reply #10 on: May 25, 2015, 01:53:28 pm »
Thanks to all, think I will get it checked over just to satisfy my concern and leave it at that
« Last Edit: May 25, 2015, 01:56:29 pm by longbelly »
« Reply #11 on: May 25, 2015, 02:08:32 pm »
I see a few repaired alloys at work,if it's holds pressure and you have had no issues it will be fine.If you bought the car of the dealer's you could take the matter up with them as to why it was missed first time round
Offline Carpy25
« Reply #12 on: May 25, 2015, 04:04:50 pm »
An older car I owned had a cracked inner rim I got it repaired and it passed four mots in the same garage same tester before he give me an advisory when I told him it had been done for years he removed the comment
As above if done correctly it should be stronger than the rest of the rim but keep an eye on it cracking right next to the weld as that's the most likely place it will go next
Rob
