Author Topic: Curb Ramp  (Read 4748 times)
Offline Ellisimo
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,79835.msg893141.html#msg893141
Curb Ramp
« on: June 08, 2015, 11:07:27 am »
Hi there, unsure if this is in the right place but I'm looking to move house but there's a slight problem with the driveway.
The curb isnt dropped and also the road is cambered where the guttering is.
So my problem is even if I spend over the odds and get the curb dropped I'll still have the problem of the front end bottoming out as the rear would go down then up before the front end. (my golf is lowered around 90mm)
So my thought is something like the Americans have (pictured) or to put some blanks of wood in the guttering so the road would be level with the curb with the addition of the wood if that makes any sense.
Any advice on what to do would be great.
Thanks!
Offline cooljimy84
    • Personal
Re: Curb Ramp
« Reply #1 on: June 08, 2015, 12:22:47 pm »
Ghetto it, i use small blocks of wood to get in to my garage, as even on the standard car it scraps...
There is no replacement for displacement....
But a turbo does help....
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Curb Ramp
« Reply #2 on: June 08, 2015, 12:23:26 pm »
I would pour a new screed myself.
You can't mess with ground drainage so put a 4" PVC pipe down first (if you have the space). This will allow water to flow by unless it gets clogged with leaves.
Shutter around the pipe in the shape of a triangle.
I would use fosroc conbectra GP which is a tough non shrink grout. That would sustain the impact from being driven over.
Not sure if the council would allow it is the only thing.
Offline Ellisimo
Re: Curb Ramp
« Reply #3 on: June 08, 2015, 01:29:02 pm »
thanks for the response.
Yea i am worried about the council, but then again a few houses down someone just drives their car straight up the curb which 'you're not supposed to do'. The idea behind planks of wood, would be that i can leave them in the porch and so the guttering wouldnt be affected. But i do like the idea of something always being there for ease of use.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Curb Ramp
« Reply #4 on: June 08, 2015, 02:17:40 pm »
I'd just go for it... If the council have a problem you could break it out with a kango in 30 mins.
If the pipe does clog then shoot the power hose through it each time you're washing down the car.
If you go looking for permission from the council you'll never get it.
Wood would be a pain. Imagine taking them out when it's raining and putting them back each time!
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: Curb Ramp
« Reply #5 on: June 08, 2015, 02:19:05 pm »
all the houses down my street who converted front gardens into drives requested the council to fit a drop curb and they all got it, well 20 out of 24 houses have  :signLOL:
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline Pesky jones
Re: Curb Ramp
« Reply #6 on: June 09, 2015, 08:46:22 am »
I was going to say don't the council have to drop it for you?
Re: Curb Ramp
« Reply #7 on: June 09, 2015, 08:52:01 am »
Yep. And they pull your pants down for the privilege.
Offline Ellisimo
Re: Curb Ramp
« Reply #8 on: June 09, 2015, 09:43:55 am »
Yea, but I wasnt planning on dropping it as the road itself is as high as the curb, it just drops down before the curb for the guttering, so I want something to basically make it a level run from the road to the curb without dropping it, because if I dropped the curb my car would just bottom out going down then up if that makes sense!
Offline Pesky jones
Re: Curb Ramp
« Reply #9 on: June 09, 2015, 09:47:47 am »
In that case I'd just do as Luke said earlier and if they kick up a fuss then break it out again and then you'll have to deal with temporary ramps.
Do it quickly and discreetly and nobody might ever notice. Mix up the stuff in your garden and then quickly whack it out there.
Offline cooljimy84
    • Personal
Re: Curb Ramp
« Reply #10 on: June 09, 2015, 09:54:27 am »
Blocks of wood get my vote.
Cheap,
Easy to remove,
Easy to replace,
Non permanent,
Offline olethalb
  • -Receive: 31
Re: Curb Ramp
« Reply #11 on: June 09, 2015, 10:08:22 am »
actually saw some rubber ramps last night against a curb while collecting some wheels.
i can confirm we never paid for a drop curb and they reshaped the whole path to a mild slope too, although as you say this may not help you.
i'd be tempted to knock up some cement and throw it down in a ramp shape against the curb - maybe with a pipe through to allow the drainage to continue, anything like rubber ramps / blocks of wood etc may draw attention and there's always some busy body on a hair trigger ready to complain about things.
Offline cooljimy84
    • Personal
Re: Curb Ramp
« Reply #12 on: June 09, 2015, 12:16:54 pm »
And that busy body won't complain about a load of cement being stuck down?
Offline olethalb
  • -Receive: 31
Re: Curb Ramp
« Reply #13 on: June 09, 2015, 01:08:55 pm »
yes but it's less obvious solution  :happy2:
Re: Curb Ramp
« Reply #14 on: June 09, 2015, 01:14:25 pm »
Just worth remembering.
Driving your car over that kerb as it stands, and up onto your property is illegal. Also putting a fixed concrete ramp in yourself also would be frowned upon by the local council paper shufflers.
You need to make some sort of removable ramps ideally.
