September 23, 2026, 01:37:22 pm
All Things Mk5
Mk5 General Area
rns 510 can bus battery drain
Topic: rns 510 can bus battery drain (Read 3950 times)
Carl
Taking part
-Given: 0
-Receive: 0
June 15, 2015, 10:47:09 am »
Hi does any1 no what can bus gateway i use for the battery drian issues when fitting a rns510 into a golf 2005
mvb12
Just look at my post count
-Given: 15
-Receive: 64
Re: rns 510 can bus battery drain
Reply #1 on:
June 15, 2015, 10:53:39 am »
7K0 907 530AK
Carl
Taking part
-Given: 0
-Receive: 0
Reply #2 on:
June 15, 2015, 11:03:58 am »
RetroRaz
-Given: 32
-Receive: 194
Reply #3 on:
June 15, 2015, 11:05:36 am »
Or any gateway with a part number ending in L or newer
http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
#RetroRaz -
https://instagram.com/retroraz/
Carl
Taking part
-Given: 0
-Receive: 0
Reply #4 on:
June 15, 2015, 11:35:41 am »
Ok one other question, is it just plug and play and where does it go or located. im new to all this as u can prob tell
mvb12
-Given: 15
-Receive: 64
Reply #5 on:
June 15, 2015, 11:38:46 am »
If its precoded then its a simple swap out plug and play jobbie.
Location details
http://www.my-gti.com/2296/can-bus-gateway-removing-installing-and-upgrading-volkswagen-golf
@Eddie-NL
can sort out a pre coded CAN
RetroRaz
-Given: 32
-Receive: 194
Reply #6 on:
June 15, 2015, 11:44:03 am »
Being 05 its most likely up above the clutch pedal
#RetroRaz -
Carl
Taking part
-Given: 0
-Receive: 0
Reply #7 on:
June 15, 2015, 11:57:11 am »
how do i get in touch with
@Eddie-NL
i cant pm any one at the mo for some reason not sure if its cos im new
pudding
Global Moderator
-Given: 2
-Receive: 692
Reply #8 on:
June 15, 2015, 11:58:16 am »
Quote from: RetroRaz on June 15, 2015, 11:44:03 am
It's there on my 07 as well. It's a lot quicker getting at it via the access panel under the wipers!
All Things Mk5
Mk5 General Area
