Author Topic: HPFP Noise  (Read 8517 times)
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: HPFP Noise
« Reply #15 on: July 08, 2015, 08:03:24 am »
yes bud, the chain came off over adjuster when removing cam, was a bit of a wiggle but bolt was stuck fast  :signLOL:
the first time i did it i just marked both cams and cam 'box' with paint pen then matched the mark onto the new cam, worked fine but wasn't ideal so i bought a cam locking tool for the next few i did  :grin:
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #16 on: July 08, 2015, 08:27:52 am »
Glad to know i'm not the only one that had problems with that bolt. So i could remove the chain/tensioner then the cam?
I would remove the locking tool while removing/replacing cam and box. Then put it back in place before replacing the chain?
05 | Tornado Red | DSG
  • -Receive: 692
Re: HPFP Noise
« Reply #17 on: July 08, 2015, 10:27:00 am »
The lobe is on my todo list. I recently listened to a 2008 gti with 80,000 km it was way quieter than mine. I keep homing in on a noise from the HPFP area. (not the chain diesel noise)
I've ordered a new purge valve which can be noisy but mine is throwing no errors.
Mine sounds a little diesely inside the car when hot and the A/C off (slower idle speed), but outside the car it sounds normal.  Also, when I listen to the engine running under the hood, all I can hear is the injectors / HPFP noises.   Are there any other symptoms or fault codes for knackered chains?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #18 on: July 08, 2015, 02:51:29 pm »
Replaced the purge valve earlier still no difference in noise. I think i'm just being paranoid. This is how it sound now.
http://daz.co/audio/purge_new.mp3
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #19 on: July 10, 2015, 09:24:18 am »
Thanks @Rob. Received the fuel pump this morning.
Offline Rob.
Re: HPFP Noise
« Reply #20 on: July 10, 2015, 11:29:31 am »
Blimey that was quick!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #21 on: July 14, 2015, 06:19:22 pm »
Fitted the HPFP i got from @Rob. :happy2:
I compared the plunger against the one i got from rob. Think mine is fooked. The plunger catches and makes a noise.
Probably the worst video ever.
[vid]http://daz.co/video/20150714_160206_333497260367818.mp4[/vid]
« Last Edit: July 14, 2015, 06:21:07 pm by dazza »
