Author Topic: Steering is twitching/notchy  (Read 3276 times)
Offline raptor_tom22
« on: July 07, 2015, 01:34:02 pm »
Hi all, having a few issues with the steering on my 2005 GTI. while driving along especially on slow bends the steering has a twitch to it almost feels like it is trying to correct itself as your driving along. The track rod ends and shock top bearings have been replaced and the steering re-tracked afterwards but the problem is still there! has anyone expereinced this or any ideas on possible faults/solutions? also the steering fluid is at the correct level and i have no warning lights of any kind.
Offline MrACD
Re: Steering is twitching/notchy
« Reply #1 on: July 09, 2015, 03:37:18 pm »
Sounds like a potential issue with the motor on the rack if it feels like it's twitching and correcting itself, that sort of feeling could only come from something motorised I reckon.
Have you had it scanned on VCDS? (I am not sure this would throw anything up).
2005 Gti - 5dr, DSG, Black
2003 Toyota MR2 Roadster, Chilli Red
2005 Honda VFR800 Vtec
« Reply #2 on: July 09, 2015, 09:14:34 pm »
Not tried VCDS yet hopefully get it checked next week and see if it flags anything up.
Offline john87
  • -Receive: 53
« Reply #3 on: July 13, 2015, 08:07:14 pm »
Did a garage tell you this?
It's an interesting point as the mk5 golf has servo-assisted power steering.. not hydraulic, so no fluid reservoir  :confused:
Regarding your issues, I felt a similar problem when I borrowed a set of wheels from a garage.. turns out the tyres were unevenly worn due to being on a car for a while which had bad tracking.  Your tyres worn evenly?
Offline Ricky123
« Reply #4 on: July 13, 2015, 09:42:10 pm »
I'd start with the free/cheap options first.
Get tyres checked and wheels for flat spots
Get underneath with a pry bar and lever suspension components and see if there's play in anything
Also worth checking springs for any broken coils
Scan it with vag com an see if it throws up any faults, maybe even try a steering angle reset? Think I've read something like that can be done on vag com.
Also I no you've said it's had new parts fitted but poorly fitted parts or cheap aftermarket parts could also cause issues
« Last Edit: July 13, 2015, 09:44:14 pm by Ricky123 »
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
