Author Topic: How to set OEM Xenons Flash to pass function properly (US STYLE)  (Read 3483 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Hi everyone,
I found it a bit annoying that when you flash your headlights when xenons are on that the shutter opens AND the halogens come on.
I tried to code this out but found that the halogens would completely disable, even when the xenons are off, they act as flash to pass. Didn't think this was safe for the ballast as you're not letting the bulb to light fully.
I found a way how to get Halogens as flash to pass when lights are off and when only sidelight is on, and ONLY the shutters open when flashing to pass when the xenons are on.
NOTE: it has to be OEM xenons and you need the shutter wires run from pin 11 from the headlights to the CECM
Hope the video below will help anyone who wants to do this.
Offline DANBOY66
  • -Given: 41
Re: How to set OEM Xenons Flash to pass function properly (US STYLE)
« Reply #1 on: July 08, 2015, 06:34:25 am »
Need to do this to my car  cheers fella
Dan..
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: July 08, 2015, 09:10:26 am »
No worries Dan. It makes it look so much better. I knew there was a way to do it coz my old gti was setup this way when i bought it.
Let us know how you get on.
Offline omeydz
  • -Receive: 50
« Reply #3 on: July 08, 2015, 02:42:07 pm »
Good job Raz  :happy2:
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline doylebros
  • -Receive: 310
« Reply #4 on: July 08, 2015, 04:20:44 pm »
Well done Raz - very well put together and educational how to video. :happy2:
Offline DANBOY66
  • -Given: 41
« Reply #5 on: July 13, 2015, 12:25:25 pm »
done this using the video and mine was a little different
it would not let me untick bi xenon so i could select it again
my flash to pass box is left unticked
and my running lights are byte 20 and was on 92x1 i changed it to 1x1
i think that was all
but they are working the same as yours are :)
Dan..
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: July 13, 2015, 12:44:52 pm »
Nice one Dan.  Might  be slightly different depending on which cecm version you have.  I done my method on 2 cars which were both 05 so might even be a year thing as well
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=o2g491raekpvn003d33gub44hb&/topic,19740.0.html
« Reply #7 on: July 13, 2015, 12:47:35 pm »
..... I need to do this, just CBA running the wires  :signLOL:
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #8 on: July 13, 2015, 05:02:09 pm »
Hmm any guide on how to get to the CECM? I've got my cables under the passenger glove box area just not sure where to go from there!
Will do all that you've got above though!  :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: July 13, 2015, 05:09:52 pm »
Run the wires behind the ashtray area and to the drivers side footwell.  The cecm is above the gas pedal in the corner.
Offline Rossimac
  • -Given: 78
« Reply #10 on: July 13, 2015, 05:14:49 pm »
Heading out now!
Offline DANBOY66
  • -Given: 41
« Reply #11 on: July 14, 2015, 06:42:21 am »
i have a MY2008 car and my cecm had a lot more options than yours did when coding  :happy2:
Dan..
