Author Topic: Stop! Oil pressure warning. Can't get rid of it! Help!!  (Read 2203 times)
Offline Grigaaa
« on: July 10, 2015, 03:48:49 pm »
Hi guys,  so a few months ago I got the
STOP!
Oil pressure
Engine off
Owners manual warning
With 3 beeps.
I then got a new oil pick up pipe fitted, oil change and I think it was also new bearings in the oil pump or something.
That got rid of the light for maybe 3 weeks then it came back.
So I got the oil pressure switch and engine speed sensor/crank sensors replaced and that didn't fix it either.
I have been looking to sell it for a while now but don't think I'll have much chance with the light coming on :(
Anything I'm missing or fixes I haven't tried yet?
Grigor
Offline doylebros
  • -Receive: 310
Re: Stop! Oil pressure warning. Can't get rid of it! Help!!
« Reply #1 on: July 10, 2015, 04:24:44 pm »
You need to do the job of cleaning the sump etc or the pickup pipe just re-chokes again!
This shows you how
http://www.mk5golfgti.co.uk/forum/index.php/topic,68442.0.html
Offline Grigaaa
« Reply #2 on: July 10, 2015, 04:43:12 pm »
Ok just asked my mechanic about this, he done that while changing the pickup pipe..
Offline doylebros
  • -Receive: 310
« Reply #3 on: July 10, 2015, 05:55:05 pm »
If I was you I'd check if you had this sensor replaced
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=9&grf=091940249&bf=91940&hgug=919&ug=19&parent_id=2361269&detail_id=2361274
If the answer is no I would - if it's yes I would have the existing wiring checked for faults and then if that checks out have the sump removed and the pick up pipe rechecked.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: July 10, 2015, 06:16:37 pm »
Am i right in thinking these engines don't have an oil pressure sensor? hence having to install one if u want an oil pressure gauge.
05 | Tornado Red | DSG
Offline Grigaaa
« Reply #5 on: July 10, 2015, 09:38:45 pm »
No I have not had that sensor replaced. I think I will recheck the pick up pipe this weekend and I'm not really clued up on the wiring tbh. So maybe need to get someone to check that
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #6 on: July 10, 2015, 09:42:02 pm »
Get an old fashioned oil pressure gauged plumbed in and actually verify the oil pressure - determine if you have a mechanical oil pressure issue, or a sensor/wiring issue
A garage can do this for you
