Author Topic: horn not working  (Read 3836 times)
Offline bagged_gti
horn not working
« on: August 05, 2015, 07:26:17 pm »
Hi guys,
Fitted a brand new mk7  steering wheel today, and was told the airbag and horn should work.
But after I fitted, the horn won't work.
What could be the problem? I've taken the airbag out again and double checked all the wires are in but no joy.
Any advice would be much appreciated
Jake
GRM Northamton stage 2 - blueflame TBE - neuspeed CAI - R8 coils
Airlift performance - SL55 AMG wheels - cayenne brakes - R32 rear bumper
A45 AMG seats - MK7 steering wheel
Re: horn not working
« Reply #1 on: August 16, 2015, 06:20:49 pm »
Most likely a coding issue or if it is a MFSW the buttons could be defective.  If you have buttons, have you tested that they work?
« Reply #2 on: August 16, 2015, 06:26:33 pm »
Hi guys,
Jake
Did the same to Dans MK5. Fitted the MK7 wheel and the horn doesnt work. I believe replacing the s/w controller fixes it
Offline bagged_gti
« Reply #3 on: August 25, 2015, 11:02:20 pm »
I sorted the problem now.
Originally I didn't have a MFSW where as the mk7 is.
I traced the wires and found the earth wire went into the the MFSW button plug. So I simply cut the wire and connected it to the correct port on the yellow plug.  :happy2:
« Reply #4 on: August 28, 2015, 04:32:38 pm »
@dansmith180
