Forum Donations 2024
on February 25, 2024, 11:16:50 am
HI Guys Its been over a year since our last request for donations. The forum kitty is empty again I have setup another donation page. The donate banner should also take you to the donation page. Thanks again for your support https://www.paypal.com/pools/c/94nqyg0CUYYou can also send paypal payments (as gift) to donate@mk5golfgti.co.uk as paypal takes a cut on donations to money pools.
NQS BBK Question/Guidance.
Last Poster: WinnowTO in Mk5 General Area on Today at 05:55:44 am
Hi all,
I was wondering if the NSQ BBK mod was achievable using 17z rear calipers from a Cayenne/Touareg/Q7. a pair of them managed to find their way into my possession and I'#039ve gone as far as seeing if they'#039ll bolt up to my current knuckle on my GTI (which they will).
Once I saw that they'#039ll bold up, I ran into an issue with them not lining up with where
Re: Volant Intake System for TFSI
Last Poster: ROH ECHT in Mk5 General Area on Yesterday at 11:18:07 pm
Just because this is old and to post a couple of things I'#039m not sure are included in the previous pages; They did upgrade the intake for the mk6 Golf R with the DV relocation... .....and the Volant did result in low fuel trims, on average, when they had MK6 Golf R people report
Re: Cambelt Change
Last Poster: Jons1001 in Mk5 General Area on May 11, 2024, 02:50:47 pm
Just to update I rang tps and they said the price for the timing belt was £212 plus Vat and then other £68 plus Vat for the waterpump VW main dealer on ebay said they can do the whole kit for £250 Inc Vat.
Re: WTF!! Has my car been mapped?? :|
Last Poster: ZoliWorks in Mk5 General Area on May 11, 2024, 12:06:31 am
With VCDS, look at boost specified, boost actual, intake air mass g/s and actual torque. You can use intake air mass and torque to estimate BHP. Take the car for a pull in 3rd gear from 3k to 5.5-6k and you should get a good enough reading. Or if you can do the same in 4th gear, it'#039s even better.
My cracked k03 turbo, on a stage 2 map, was underboosting by 0.3-0.4 bars
Re: Milltek vs Pipewerx
Last Poster: ZoliWorks in Mk5 General Area on May 10, 2024, 10:04:52 pm
Yeah that's the one. Tho it's funny. The rest of the exhaust on the Jetta is stock while the downpipe is custom all the way back to under the rear seats where it's connected to the exhaust. On the golf the whole system is stock, minus the cat, which is a sports cat.
Re: Where would you go with £23k
Last Poster: pudding in Mk7 General Area on May 10, 2024, 05:50:28 pm
They are all good choices if you want to stay with VAG. nbsp The RS3 will have you at the Shell station quite often and you'#039ll have boy racers up your backside constantly nbsp nbsp They go and sound amazing though. I'#039m the same age and went from an Edition 30 to an F30 330d, mainly due to the massively increased mileage, but it'#039s proven to be a quick and fun car. <
Re: Forum Donations 2024
Last Poster: dazza in Announcements on May 10, 2024, 03:36:03 pm
Hey, donation link is closed. I'm ready to send in my first euros after nearly 3 years of being on this great forum. Thanks
Just added a new money pool. Thanks again for all your support guys.
Replacement Mk5 GTI rear passenger door
Last Poster: g7jhp in Mk5 General Area on May 10, 2024, 03:15:38 pm
Hi All, The other half managed to put a hole in the passenger side door, so I need to find a replacement door rear passenger door ideally in The same grey.
The cars a 2008 Golf GTI Mk5, 5 door paint code LA7T.
Do all Mk5 doors fit?
Should I just be able to move the hardware over?
Re: Mk5 gti code p0299
Last Poster: Reeceyy in How to Guides / Troubleshooting on May 09, 2024, 01:37:38 pm
I also have the p0299 code. Ive just noticed that i have the hairline crack on the turbo, exhaust side too. Still boost well the car and theres no strange whistles. The problem with my car is that its also leaking oil badly and im still not sure where its coming from. Is yours leaking oil too?
Re: Bad oil leak and now low oil pressure
Last Poster: OllieVRS in Mk5 General Area on May 07, 2024, 08:49:23 pm
Ironically you can get low oil pressure from over filling the oil. But I suspect it'#039s something more serious in your case that must be investigated ASAP.
Doing what ZoliWorks said is a good start. Places on the right side of the engine to check out are the oil filter housing, cam chain housing and oil cooler. The valve cover gasket can leak too but not enough to cause l
Sold 2008 Volkswagen Golf GTi Edition 30 - Steel Grey - 5 Door - Stage 2+ (DSG) £10995.00 Location: West London Collection Only
Hi all,
For sale is my 2008 Volkswagen Golf GTi Edition 30 (DSG). I am the 2nd owner from new and have owned the car since November 2021. The car was near enough stock when I purchased it and I have upgraded it in my ownership.
- 5 door. - DSG. - Steel Grey. - 76,000 miles (will rise as still in use). - FSH - last serviced December 2023. - MOT - Expires 7th March 2025. - Xenons. - Heated seats. - Highline MFD. - Arm rest. - MFSW. - RNS510. - Folding mirrors (heated). - Rear parking sensors.
In my ownership I have had the following maintenence completed:
- Serviced 3 times (2 full services, one oil and filter change). - Cambelt and waterpump. - Thermostat replaced. - DSG service. - Genuine cam chain and tensioner. - Genuine cam follower changed at every service. - Genuine oil pick up pipe. - Rocker cover gasket. - Genuine PCV. - Genuine Diverter valve. - Subframe spacer kit. - Brake vacuum gasket. - Varta E44 heavy duty battery. - New rear wiper switch. - New folding mirror switch.
Upgrades/modifications are as follows:
- Brodit angled mount. - Suede retrimmed headliner. - Wheel finesse steering wheel wrap. - Ram air oversized induction kit. - Turbo back exhaust comprising of an MPD developments downpipe with sports cat and a Miltek cat back. - VIS Stage 3 HPFP internals. - Genuine R8 coilpacks. - MK7 Golf Gti performance front calipers, discs and pads. - Tuning technics Stage 2+ lite remap (approximately 355-360bhp). - Tuning Technics DSG remap. - H&R front and rear anti roll bars - fitted December 2023. - Whole car has had Powerflex bushes installed in December 2023. - Super pro anti lift kit - fitted December 2023. - AP coilovers (top mounts replaced all around at the same time), fitted December 2023. - All rear control arms replaced (December 2023). - Geo By Luke fast road alignment (December 2023). - Michelin Pilot Sport 4 tyres all around.
I've just spent circa £2.5k on the suspension components refresh.
I have spared no expense on ensuring the car is mechanically sound.
Being honest, the car could do with the wheels being refurbished. There is general wear and tear on the car which is expected for the age, the car is approaching 16 years old. There are some minor dents and scratches. The front end does have some stone chips. The inner sills have some slight blistering to the paint. The MFSW buttons work intermittently but I have bought the new control module but haven't had this fitted yet. The cruise control is also intermittent and I have purchased a new stalk, but haven't fitted this yet. Parts will be included in the sale, or if I have time, I will get them installed before sale.. Front and rear dash cams & pioneer double din are not included in the sale.
If you are looking for a well sorted car which mechanically has been looked after well, this is a good car to purchase.
I am in no rush to sell, only considering selling to upgrading. No part exchanges please.
The pictures are prior to the installation of the coilovers, I will upload new pictures once I have detailed the car.
I'm looking for £11,495.00, I paid just under this when I bought the car stock.
Please let me know if you have any queries.
Kind regards,
Sharif
2 x Mk5 Gtis being broken, West Midlands £0.00 Location: Walsall, West Midlands Postage: £0.00 Delivery or Collection
I have, in annoying and frustrating circumstances, ended up with 2 Black Gtis that are both dead on my drive, both for engine reasons, so I couldnt even get away with making a good one out of the two, and have had to replace them both with an R32!
I will start pulling them apart and will list stuff separately as I have the chance, however, due to lots of stuff that is going on at the minute, that may take me ages, so I thought a general post about both being broken may be helpful for anyone who is after specific bits etc.
One is an 05 5 door, block and head are totally scrap. Was in daily use until a couple of months back when the engine lunched itself. Pretty much all standard. Of note off the top of my head has: - Heated Leathers in decent condition - Standard Grey Leather Gti Steering wheel - 17" Monzas with decent Tyres - Midline Clocks - Generally things are pretty tidy, so anyone who needs standard bits like engine cover, trim, light covers etc etc etc, they might be of use to you.
One is an 06 3 door, with a few more tasty bits and pieces on, but that has been sat for longer. Again, engine itself is lunched. Again, from the top of my head there is:
- Heated Cloth interior in not bad condition - Black MFSW - Cat Back Stainless, although the cat itself was getting borderline on MOT passes, so maybe just the backbox of use - 18" Monzas - Neuspeed Intake - Twintercooler Setup - Reversing sensor setup rear bumper etc - Highline clocks
There will be other decent bits on both - As I say, I am working a bit off memory at the minute.
I just need the cars gone, so once I get started, really I just need it all out the way, so not especially bothered about getting top dollar for bits, I just need the space back, but know that the bits on them both are too good to let go for scrap.
I am based just outside Walsall in the West Midlands, but work in Cardiff, so go there most weeks, and am happy to take stuff there (or meet people in between).
Shout if any questions, and as I actually get stuff off I will get pictures up, but if people want me to get pictures of anything specific, let me know and I can do. I am actually listing this right now when I am away from home with work for a few days, as thats the only way I actually get time to, but feel free to send me questions etc and Ill answer best I can, then send pics when I get back.
I dont love posting car bits out - There is too much room for stuff to get damaged, go missing etc - I would much rather collections, or meet you somewhere etc in an ideal world, but it can possibly be arranged on some stuff.
Dan
- Users: 6
- Guests: 381
