Author Topic: Clutch slipping... Helix still the one to get?  (Read 25780 times)
Offline AJP
  • -Given: 392
  • -Receive: 317
« on: February 15, 2016, 03:09:28 pm »
My clutch has been slipping a bit today, in 6th at 2.5/3k under full load.
Reason for that is the new turbo-back Powervalve... on top of the stage 1 R-Tech there's now just too much for the clutch.
So, am I right in saying the Helix Organic with a new oem flywheel is the way to go? I may be going hybrid k03 at some point so it'll need to be able to cope with 400lbft.
Any info, links etc appreciated. Cheers!
  • -Receive: 692
Re: Clutch slipping... Helix still the one to get?
« Reply #1 on: February 15, 2016, 03:52:26 pm »
Yeah that's a good choice.  Pedal weight is roughly twice that of a new OEM one but it can take the torque.  No judder either, which is nice as many aftermarket ones do.
You need to tell Helix which brand of DMF you're using, so order that first.  Be prepared for a wait on the clutch too.  Got mine last year but hate to wait a month!
Offline ed30Lewis
  • R-Tech Stage 2+ Candy White Ed30 #2219
« Reply #2 on: February 15, 2016, 03:57:21 pm »
As above, Helix organic clutch is what you need. Once its bed in, its like OEM but better.
I have The Helix Organic Clutch with a oem LUK DMF. Its coping with my stage 2+ eddy at 397lbft no problem. Mine was ordered through awesome GTI and the wait time was a week  :happy2:
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #3 on: February 15, 2016, 04:32:06 pm »
Cheers lads, good info.
Unfortunately I'll have to wait a few weeks til I get the funds together as I was quietly hoping the clutch would cope... bad assumption on my part.
I'm also booked in with Niki on 24th to tweak the map to the exhaust - think I'll have to cancel that - no point trying to squeeze more out of it on the rollers if it's struggling now.
Steady driving required for a bit then!
Offline BradCobbs
« Reply #4 on: February 20, 2016, 01:24:29 pm »
I've had the same problem in the last couple weeks which is gradually getting worse.
With 130,000 miles on the clock I think it has done well.
Will an OE clutch simply not take the extra torque that stage 1 provides? I've done roughly 8,000 miles since the remap.
Obviously an uprated clutch is the way to go, but they are significantly more expensive.
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #5 on: February 20, 2016, 06:05:52 pm »
From what I gather, an oem clutch should handle stage 1 levels of torque, but simply won't last anywhere near as long as it should.
I suppose it depends how long you plan to keep the car, and if further power mods are a possibility down the line. For me, I'll be keeping the GTI for a good 5+ more years and I am planning more power, so it wouldn't make sense to go for another oem clutch in my situation.
Also if you look at the job as a whole, done right with a new flywheel, plus labour, it's a dear job whichever way you look at it. The clutch itself is just one part of the job so you're not going to be saving a huge amount relatively.
I like the idea of having a clutch that you can put 400lb/ft through. Not sure the con rods will be too happy but that's just another a bridge to be crossed when it arises..
Offline Madone
  • -Receive: 27
« Reply #6 on: February 21, 2016, 09:14:42 am »
The oem clutch will take stage 1 without a issue, I am at stage 2+ on a edition 30 on a standard clutch. All ok so far...., will change to a upgraded on once it does go. But at stage 1 I wouldn't go upgraded. Upgraded clutches will have firmer pedal, that's a compromise which is unnessesary at stage 1.
Offline rashg60
  • -Receive: 41
« Reply #7 on: February 21, 2016, 09:26:38 am »
AJP that is bad news man! I guess you, like me, were hoping that the standard clutch would hold. Now you're beginning to frighten me, as I didn't wanna go down the route of clutch replacement. Thankfully mine is holding up just fine at the moment.
Since our cars similar, I suspect it won't be too long before mine will start to play up too.
I actually have no idea about uprated clutches or what needs replacing etc. By the sounds of things it seems very expensive. Please do keep me updated on your progress, as no doubt I'll be crossing this bridge sooner or later.
PS - you free next weekend?
Previous motors (in order of succession since 1994):-
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
VW Corrado G60 Supercharged
Volvo C70 2.0 Turbo Convertible
Audi TT MK1 1.8T quattro (225)
Mercedes CLS 320 V6
Audi TT MK1 3.2 V6 Quattro
Audi A4 Convertible 1.8T Quattro
VW Golf MK5 GTi 2.0 Turbo
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #8 on: February 21, 2016, 10:38:07 am »
I think it's just bad luck mate, yours could be ok for a long time to come, but maybe keep a little fund to one side just in case..!
I'll pm you now regarding the bumper
  • -Receive: 692
« Reply #9 on: February 23, 2016, 12:39:40 pm »
A brand new OEM clutch can cope with 300lbft, just.  One that's beyond half worn, doesn't like it and has been demonstrated enough times now that it's almost a fact!
Also, bear in mind VW only rate their FWD turbo gearboxes to a maximum of 280lbft, so over-boosting our cars puts us all on borrowed time anyway....but I digress....
.....Just to add some context to this because forums tend to be black or white with these things..... I am talking about peak boost / torque when the car is over-geared (so 6th on the motorway), peak boost up a hill in 4th and sometimes 3rd.  Most of the time on a flat or slight down hill and with the wind behind you, the clutch can cope with it.  Throw a cold winter's day into the mix and the variables all change again!
Just prior to getting my clutch done and with Revo, it was spinning up 3rd like clockwork, in the dry.  After it was custom mapped, it was barely wheel spinning at all and just didn't feel as responsive when in boost.  Why? Because the damn clutch was slipping!!!  Threw the helix in and it's 'f'ck me', what an animal!!!
« Last Edit: February 23, 2016, 12:42:13 pm by Pudding »
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #10 on: February 23, 2016, 12:55:40 pm »
Can safely say I agree with this!
Offline BradCobbs
« Reply #11 on: February 23, 2016, 05:38:44 pm »
So in regards to the flywheel replacement, has anyone actually had any problems with them?
I've only ever encountered issues with Diesel Dual Mass Flywheels as the vibrations from compression strokes are far greater than those of a petrol.
I'm a mechanic so I'll be doing the work myself and think I'm gonna chance mine and just go with the clutch. I'm sure that'll come around to bite me in the arse, it's inevitable.
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #12 on: February 23, 2016, 08:53:38 pm »
I think the point is that if you're in there doing the clutch it's pointless to leave in a flywheel that's got maybe 6 months on it.
By all accounts an oem dmf works well with the Helix.
  • -Receive: 692
« Reply #13 on: February 24, 2016, 10:46:32 am »
Tbh, if the original DMF isn't rattling, I'd be tempted to leave it.   I replaced mine as a matter of course but I noticed a brand new one is just as loose and sloppy as a 75K old one.  Complete pieces of sh1t those things are.
You must specify to Helix whether your DMF is LUK or SACHS at the time of order though.  I've used both brands and they're as bad as each other, so take your pick!
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #14 on: February 26, 2016, 11:58:16 am »
Well I've messaged @vRSAlex so I'll pick his brains and see what the best option is.
