Author Topic: URGENT oil pressure stop engine  (Read 229672 times)
Offline Pesky jones
« Reply #690 on: April 09, 2016, 09:11:58 pm »
I cant see any oil dripping... il check tomorrow am. Ive lugged the block 91 and its giving an actual of 33 kw now. Im not really bothered tbh.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #691 on: April 09, 2016, 09:16:34 pm »
Specified and actual match? I did say it was only a tooth out  :signLOL:
Very lucky man not to have damaged anything.  :happy2:
Offline doylebros
« Reply #692 on: April 09, 2016, 09:18:37 pm »
Well done Pesky you've had plenty opportunities to quit!
Tomorrow the engine bay needs all excess oil removed before further testing, especially the top of the gear box, as it will have pools of oil in the casting webs, which will fool you after a test drive thinking you've got issues.
Offline doylebros
« Reply #693 on: April 09, 2016, 09:19:58 pm »
Pesky don't forget to thank all your posters as support keeps us all going! :congrats:
Offline Pesky jones
« Reply #694 on: April 09, 2016, 10:10:17 pm »
No specified is still 28 however actual is 35. Is it that big of a deal? I dont fancy doing all this again only for it to potentially end up worse.
Yes, I owe everyone in the thread a massive thankyou, some especially. Without the forum I wouldn't have had a clue where to start. Very gratefull.
Offline doylebros
« Reply #695 on: April 09, 2016, 10:48:26 pm »
I think there's plenty educational aspects in this thread and is worth adding to this how to thread list http://www.mk5golfgti.co.uk/forum/index.php/topic,52731.0.html
I feel it shows if your keen enough there's help and support from fellow enthusiasts to help members undertake a job which would never be normally contemplated by them.
So if Dazza or another mod thinks the same may be it will be added for Pesky's determination!
Offline Pesky jones
« Reply #696 on: April 09, 2016, 10:58:17 pm »
Heres the video of the start up. Upon watching the video, the engine doesnt sound as good as it does in real life. It ran consistently for about 15 minutes. I think im nearly there, just got to watch out for leaks as doylebros says!
Offline vRSAlex
  • -Receive: 253
« Reply #697 on: April 09, 2016, 11:03:01 pm »
It's still on cold start. Will be fine when warm.
Follow AKS tuning on Facebook
Offline Pesky jones
« Reply #698 on: April 09, 2016, 11:05:21 pm »
Hmm I probably took these readings five minutes into running. It would be warm by then wouldnt it? Unless its to do with my inline stat problem (long time to get to temp) next job...
Offline vRSAlex
  • -Receive: 253
« Reply #699 on: April 09, 2016, 11:07:16 pm »
Give it some more time.
Offline doylebros
« Reply #700 on: April 09, 2016, 11:08:36 pm »
I find It's always best to have the latest PCV fitted to these engines, I've even had a few PCV fail after turning the cam cover upside down, so as you progress and build a list of jobs to do, check what revision you currently have fitted.
Let's see how it responds under load once you've done all your checks,testes,scans and given the engine a chance to reset a few values.
Offline Pesky jones
« Reply #701 on: April 09, 2016, 11:10:18 pm »
I have the latest pcv, fitted it when I first got the car. I also did the dipstick pcv test and it passed. Will give it some time and re test the values.
Alex, pm'd you about the vacuum pump
« Last Edit: April 09, 2016, 11:12:49 pm by Peskyjones »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #702 on: April 10, 2016, 10:16:28 am »
Good work mate sounds better than mine.
When you DIY your cambelt change to the two piece belt cover.
05 | Tornado Red | DSG
  • -Receive: 445
« Reply #703 on: April 10, 2016, 11:11:57 am »
It sounds like it's sorted mate,don't for get when it's stood still ticking over it will take a while to warm up,as Alex says give it time
Offline Pesky jones
« Reply #704 on: April 10, 2016, 06:32:20 pm »
Taken it out today for abour an hour. Drives and pulls fine, no horrible noises. Sounds better then before now, with the new chain and tensioner. I forgot my laptop now, going to look at the timing in about an hour.
Im honestly over the moon, couldnt have done it without everyones help I cant thank you guys enough  :happy2:
