September 02, 2026, 10:41:54 pm
All Things Mk5
Mk5 General Area
Missfire. need help asap
Topic: Missfire. need help asap (Read 2830 times)
K9
Just look at my post count
-Given: 1
-Receive: 14
VW LifeStyle
April 11, 2016, 05:15:33 pm »
Sup. i'm getting codes like random missfire and 2 codes that say cylinder 1 & 4, this only happens sometimes when pushing true gears to redline. runnng stage 1+ with v-power.
what should i check first?
dronners
Always Involved
-Given: 7
-Receive: 34
Re: Missfire. need help asap
Reply #1 on:
April 11, 2016, 05:20:29 pm »
coilpacks and sparkplugs first port of call id say
fab5freddy
-Given: 238
-Receive: 239
Reply #2 on:
April 11, 2016, 05:42:22 pm »
As above, plugs, i've replaced two in the last 2 weeks
K9
-Given: 1
-Receive: 14
VW LifeStyle
Reply #3 on:
April 11, 2016, 05:50:12 pm »
Quote from: dronners on April 11, 2016, 05:20:29 pm
will check tomorrow
shoaybmakda
-Given: 25
-Receive: 54
Reply #4 on:
April 11, 2016, 06:12:58 pm »
This.
If these are fine then could be your injectors as I eventually found out. But definitely start at that point first.
Johal87
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Reply #5 on:
April 11, 2016, 07:14:43 pm »
I just had this, mine was injector 3, did plugs first, but because it was the injector it messed that plug up again so had to do the plugs again anyway
ROH ECHT
-Given: 113
-Receive: 149
K04 PLAY....ZOOM DIS!
Reply #6 on:
April 11, 2016, 08:33:45 pm »
I always have new coils in the garage because they will cause misfires when they begin failing rather than reaching complete failure. If I swap one out and the problem is fixed...it was the coil. If not I check the plugs and replace if nearing the time when I usually replace them...and by checking I mean I gauge them and replace if their gap has increased. If the gap is larger...you have burned through their coating and pointless to re-gap. If still exists...the injectors, but haven't had to go that far yet being at 127k miles total with just 67k miles on the S3 injectors that were installed with my K04 upgrade.
K04 PLAY...K04 turbo/S3 INJ. & FMIC/FORGE FMTC, TB hose, & WG actuator/GIAC's H.O. K04 & DSG TUNES/AWE DV/NEUSPEED P-FLO,TURBO OUTLET & TB pipe/AUTOTECH hpfp/BSH Eng.&Trans Mounts/H&R ARB's/Whiteline Performance springs & W.A.L.K./ECS stage-3 BBK/BILSTEIN B8's...ZOOM'DIS...GIAC K04 tune-2007 Volkswagen GTI: 12.823 @ 112.050 MPH__Voting for my Dragtimes link:
http://www.dragtimes.com/Volkswagen-GTI-Timeslip-25700.html?r=1
K9
-Given: 1
-Receive: 14
VW LifeStyle
Reply #7 on:
April 13, 2016, 10:57:07 am »
whats hould the gap be between NGK plugs? they were now 0.80
All Things Mk5
Mk5 General Area
