Author Topic: Changing brake discs and pads  (Read 1229 times)
Offline howie1987
  • -Given: 92
  • -Receive: 20
« on: April 15, 2016, 10:15:44 am »
Am changing brake discs and pads at the weekend on my edition 30.
Is it just a matter of changing them and topping up my brake fluid. or do i need to plug it in to vdcs?
Idealy i was going to change the brake fluid aswell but am reading  i need vdcs which i don't have.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Changing brake discs and pads
« Reply #1 on: April 15, 2016, 10:17:22 am »
I changed mine a couple of years ago without vcds.
05 | Tornado Red | DSG
Offline howie1987
  • -Given: 92
  • -Receive: 20
« Reply #2 on: April 15, 2016, 10:56:13 am »
i'll give it a bash see how it goes then.
Offline Paradox1
  • -Given: 41
« Reply #3 on: April 15, 2016, 11:33:59 am »
You don't need to VAGCOM to change the fluid. only if you want to drain the ABS Pump.
When you push the pistons back, you will need to open the brake res. when you push the piston back the fluid will go back to the original level
