Author Topic: r-tech remap clutch help  (Read 8781 times)
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: r-tech remap clutch help
« Reply #15 on: May 24, 2016, 05:43:58 pm »
@Blackgtiman
Fit an uprated Organic clutch combined with a OEM DMF (personnal preference Id recommend Helix so speak to Alex at AKS Tuning). I ragged the hell out of my 2+ Eddy for 3 years and the Helix Clutch was immense.
Yep, I love mine. For a few extra quid I know it'll take everything the BWA will be able to throw at it.
Offline Madone
  • -Receive: 27
« Reply #16 on: May 24, 2016, 05:55:28 pm »
Thanks for the replies. I did ask for switchable maps but nik said my ecu would not take them. Im waiting for nik to come in today to speak with him regarding the issue. I dont really want to go down the upgraded clutch path but i also dont want to put another luk in and still find it slips.
Drive around the issue (i.e. drive it properly and rev the thing!) until you have the money to change the clutch and DMF. If sticking with stage 1 or stage 2 then a standard one is fine..... Parts are around the £300-350 mark, plus labour
Do you not have switchable maps?
You definitely don't need an updated clutch, standard will take all a mapped K03 can muster (if you don't go silly and perform constant traffic light starts). Standard clutch drives nicer than a heavier updated version.
Offline Wolf Burger
« Reply #17 on: May 24, 2016, 07:09:17 pm »
@Blackgtiman
I've been looking at an uprated clutch for my Mk6R any reason for the Helix over a Sachs one?
How heavy do you find it over standard???
Golf Mk6R 2011- Rising Blue- Manual-
Modifications-
E-Tuners 361 BHP - 350lbs
Revo Intake
Bilstein B16 & H&R ARB's
Team Dynamics 1.3
18Z Porsche BBK
RNS510 with Focal Speaker upgrade
MK6 Recaro Heated Buckets
Cruise Control
Highline Reverse Camera
Offline Blackgtiman
« Reply #18 on: May 24, 2016, 09:41:10 pm »
A few different reply's there, thanks.
r-tech have agreed to put a new map on with less power/torque. Ill see how that goes and when/if it slips again ill to go for a luk clutch and flywheel from carpartsforless. I really don't want to spend out on uprated parts or change the feel of the clutch.
Offline Octoparrot
  • -Receive: 104
« Reply #19 on: May 24, 2016, 10:44:34 pm »
Is it just me that is surprised it slips in sixth and not in the lower gears?
dansmith180
« Reply #20 on: May 24, 2016, 11:41:16 pm »
No that's when it usually happens, high gear - low rpm's. All the torque puts lots of strain on the friction plates, when in lower gears it spins more freely and so doesn't slip or slips much less.
« Reply #21 on: May 25, 2016, 11:26:12 am »
@Blackgtiman
@Wolf Burger
No reason for Helix over the Sachs alternative other than Alex at AKS recommended it and that is and was good enough for me. Plus I had my Eddy's torque taken up to 420ft lb while having the 2+ map done by Niki a few back and it was still holding strong........as I said.........immense clutch (had it taken back down to 370ft lb as not to tempt fate).
Offline Wolf Burger
« Reply #22 on: May 25, 2016, 11:49:47 am »
@Blackgtiman
@Wolf Burger
Thanks for the info!
I am just worried about how heavy an uprated clutch will be!! Were you DSG?
Modifications-
Revo Intake
Team Dynamics 1.3
18Z Porsche BBK
Cruise Control
« Reply #23 on: May 25, 2016, 12:15:03 pm »
Manual.
After first having it fitted it was no more than approx 30% heavy but soon bedded in and was no heavier/stiffer than the previous OEM feel. Overall a much better feel IMHO.
Offline Blackgtiman
« Reply #24 on: May 25, 2016, 09:36:23 pm »
what sort of money are the upgraded clutchs? carparts4less do the luk one for a very good price of 125!
« Reply #25 on: May 26, 2016, 09:06:39 am »
@Blackgtiman
Have a look at a previous GB Alex at AKS did, similar prices these days I imagine. Should be able to get an uprated Organic clutch (plus fit a new DMF at the same time) and fitting for all under £1k so not to bad.
~~ Clicky here ~~
« Last Edit: May 26, 2016, 09:43:24 am by MC71 »
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #26 on: May 26, 2016, 12:12:56 pm »
OEM LUK clutch, DMF and CSC = £325 ish quid from Carparts4less with discount codes applied
Uprated Helix item and new DMF = RRP £880+ apparently, although seen plenty obtain them for the £750 mark.... still double the price when it isn't needed at Stage 1
« Last Edit: May 26, 2016, 12:14:29 pm by Dan_FR »
Offline Blackgtiman
« Reply #27 on: May 26, 2016, 12:36:07 pm »
thanks dan, yes big jump in price. best price I got on CP4L is 380 for clutch, fly, slave and bolts. I used code clutch10
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #28 on: May 26, 2016, 01:08:58 pm »
Their prices are high at the moment, higher than usual - probably because they're offering the 10% clutch code
£380 is still a lot better than the RRP of £880. I'd wait it out or shop around elsewhere
Just checked Eurocarparts...... Clutch, DMF, flywheel bolts and a new CSC (you need all of this) is currently £364.92
« Last Edit: May 26, 2016, 01:12:27 pm by Dan_FR »
