August 24, 2025, 04:07:38 pm
All Things Mk5
How to Guides / Troubleshooting
Drivers door gap
Topic: Drivers door gap (Read 3165 times)
Craig Stanley
Always Involved
-Given: 14
-Receive: 16
Drivers door gap
June 25, 2016, 07:03:19 pm »
Hi. Can anyone help me. My drivers door has about a 5mm gap at the top wher the rubber on the door meets the roof. It aligns perfectly all around the door but just doesnt seal at this point. If I push on it at the top corner it closes the gap. Is there anyway to adjust it like bend it or something or am I best taking it into a bodyshop. Cheers
Sent from my SM-N910F using Tapatalk
Andy
Admin
Just look at my post count
-Given: 39
-Receive: 447
Re: Drivers door gap
Reply #1 on:
June 25, 2016, 08:59:41 pm »
Years ago you put the window down and pulled the top of the door in but the golf doors are pretty strong and you have to watch you don't crack the paint
gttdi build thread
r32 build thread
Craig Stanley
Always Involved
-Given: 14
-Receive: 16
Reply #2 on:
June 25, 2016, 09:57:55 pm »
I did think of doing that. Might have a crack at it tomorrow as there is no paint on the top section apart from on the inside. Cheers
r5gtt
-Given: 342
-Receive: 334
Reply #3 on:
June 25, 2016, 11:32:27 pm »
Be careful when pulling as you don't want to snap the frame.
Last Edit: July 05, 2016, 07:12:37 pm by r5gtt
ChazGTI
Always Involved
-Given: 3
-Receive: 2
Reply #4 on:
July 05, 2016, 03:38:14 pm »
It might be an idea to undo the bolts and try realigning the door (with help) , I need to do that on mine as the lower part of the door catches the door still ever so slightly. Not sure if it's that simple though.
Stupots
Always Involved
-Given: 18
-Receive: 35
Reply #5 on:
July 05, 2016, 04:53:32 pm »
Mine was like this. I wound down the window, stuck my leg in the gap (maybe use something other than a leg) and pushed on the top corner of the door. I took me 2 goes to "adjust" it enough but now it lines up perfectly; took all of 30 seconds to fix something that had annoyed me since buying the car.
(I take no responsibility for any damage you cause should you decide to give this a go)
Good luck
Stu
lukemk5gti
-Given: 28
-Receive: 118
My Ride:
Reply #6 on:
July 05, 2016, 05:14:22 pm »
The girlfriend recently damaged her car and water is now getting in at this corner.
Might attempt the leg in and bend method later!
All Things Mk5
Drivers door gap
