Author Topic: Any differences in the front headlight level sensor?  (Read 8368 times)
Offline Gmac
  • -Given: 30
« on: September 26, 2016, 02:02:42 pm »
Hi folks,
My front sensor is broken, so looking to get a replacement.  I'm just wondering if all the golfs have these?  Or is it specific to gti or Xenons?
Many thanks :happy2:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Any differences in the front headlight level sensor?
« Reply #1 on: September 26, 2016, 02:43:42 pm »
Which sensor?
If you have xenons from factory then you most likely have the auto leveller which is under the passenger wheel well connected to the wishbone.
Or are you talking about the one in the cabin beside the light switch that you turn from 0 to 2 to change their position?
Offline PatchySan
  • -Receive: 59
  • Gracie!
« Reply #2 on: September 26, 2016, 02:47:35 pm »
I think the headlight auto leveling sensors are fitted for Golf's with the factory Xenon options only. My GTI had a broken leveling sensor where the arm broke off and would have failed the MOT. Though a mechanic who was aligning my wheels warned me about it a couple of weeks before my MOT test so I had time to buy the part cheaply and get it replaced there and then to save time.
I bought my OEM auto leveling sensor from AliExpress (part number:  1T0 907 503B) for £34, fitted fine and passed the MOT thereafter. Otherwise it would've been about £110 so saved myself a bit there!  :laugh:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: September 26, 2016, 03:40:38 pm »
Not the case. If your leveling arm is broken you won't fail an MOT. As long as the headlights are still straight on it's fine.
Many people break theirs and it's just a case of cable tying it at the midpoint.
The auto leveling sensor is only handy if you have a heavy load in the boot and you don't want to blind oncoming traffic.
Offline Gmac
  • -Given: 30
« Reply #4 on: September 26, 2016, 05:49:57 pm »
Cheers for the replies folks...
So to be clear.. It's the auto sensor attached to the front suspension.
So are we saying it is only cars fitted with Xenons that have this levelling sensor?
Offline 99hagued
« Reply #5 on: September 27, 2016, 12:32:57 am »
[/quote]
A defective sensor is a fail mate
Offline Gmac
  • -Given: 30
« Reply #6 on: September 27, 2016, 07:03:15 am »
Is it only xenon specced cars that have the auto levelling sensor?
Offline 99hagued
« Reply #7 on: September 27, 2016, 08:42:16 am »
Usually it is
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #8 on: September 27, 2016, 10:12:43 am »
How will they know to look for a broken sensor in a car that's hidden in the wheel well which gives no dash light errors if your headlights are in the correct position as is?
The sensor is a luxury not a requirement.
They only requirement is that your lights are aligned and at the right height.
Yes I believe it's only factory spec xenons with this option.
Offline 99hagued
« Reply #9 on: September 28, 2016, 02:26:23 pm »
If a car with xenon light are fitted with self levelling lights and washer they have to work so a sensor with a broken linkage would be a fail
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #10 on: September 28, 2016, 02:33:15 pm »
Obviously you're the expert here!
 :pomppomp: :pomppomp: :pomppomp:
Offline 99hagued
« Reply #11 on: September 28, 2016, 02:36:15 pm »
I know enough to get by matey :P
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #12 on: September 28, 2016, 03:04:41 pm »
Cop on will you, you shouldn't give bad advice to fellow members.
You're wrong about the MOT and the broken sensor. 3 friends, me included have all passed with a broken sensor.
Think about this logically and don't be close minded. How would a tester in the MOT know to look for a physical crack in a sensor hidden in a wheel well that gives no dash lights? If the lights are pointing the way they should then it's a pass.
Offline 99hagued
« Reply #13 on: September 28, 2016, 04:13:10 pm »
I'm taking about the linkage that connects the sensor to the suspension broken, obviously if it was hidden you would be able to fail what you can't see but there usually pretty visible. Sorry if I misunderstood
