Author Topic: Clunking from front end - steering rack or suspension??  (Read 9090 times)
Offline sixpot
Re: Clunking from front end - steering rack or suspension??
« Reply #15 on: February 01, 2010, 09:10:43 pm »
I'd put money on it being the track control arm bushes. Mine were knackered, and caused a banging noise over every bump.
how much are these ?
Can't remember the price but the inner ball joints were that worn the whole arm was replaced (both sides) and new track rod ends fitted to the arms. after they had been removed I stripped them down and found water had ingressed into them, thus causing the wear. Car was just out of warranty, so I took the case up with VW customer service to try and get some compensation for the cost of replacing them. Never heard from them again!!
You can do an easy test to check for this type of wear, by jacking the front wheels off the ground and rocking the wheel up and down and side to side. If the joints are worn the wheel will wobble a bit and you should be able to replicate any noises you hear by increasing the force you apply to the wheels.
Offline DaveyCupra
« Reply #16 on: February 15, 2011, 11:52:31 am »
sixpot:
Do you mean the arms coming out of the Steering rack and the track rod ends were replaced? Or do you mean the Wishbones and the Track Rod ends were replaced?
Getting the same noise issue on my Cupra, up to 40mph over every bump hear a bang out of front driverside area. Changed the Anti Roll Bar drop links and no joy. New top mounts added last summer with new shocks and lowering springs so not them items already.
Car has covered 43k how many miles were on yours when they went?
Offline em2evol
  • Let's Motorvate!
« Reply #17 on: February 15, 2011, 12:46:25 pm »
I had this on mine - had it's MOT on Saturday so asked them to check it out - turns out the mounts are damaged from where I crashed into a pothole and had the suspension arm replaced... Just waiting for the quote for repair now... :popcornsoda:
