Author Topic: Fault code p0030  (Read 5354 times)
Offline Ant b
Fault code p0030
« on: November 12, 2017, 10:28:28 pm »
Hello I fitted a decat 2 days ago and after a 10 min drive the engine light came on so reset it then again 10 min later came on again,isn’t the code the top senser that dosent normally have an issue with decats.
It never came on before,and it undone out of the old downpipe fine so I don’t think I broke it,
I’ve checked the plug and that’s fine.
Is my only option to buy a new one.
red mk5 golf gti ks05 fak,ram air intake,3” downpipe/decat,dv+,bcs rev ll exhaust stage 1 remap.coilovers,whiteline rarb and depo projectors,
Edition 30 front splitter,r32/gti rear,r32 side skirts
Soon to be r tech stage 2
  • -Receive: 692
Re: Fault code p0030
« Reply #1 on: November 13, 2017, 10:07:53 am »
No it's the second sensor seeing too much oxygen in the exhaust.   If the primary sensor failed, you would know about it.  It would run like a sack of hammered crap.
Offline Ant b
« Reply #2 on: November 13, 2017, 03:42:50 pm »
It’s says bank 1 senser 1 isn’t that pre,it’s never come on that soon in any other cars tho if it is post
https://s20.postimg.org/fyh8nnjul/2_C1_D5430-_C437-4_A57-8_D87-3_B8175802_CE6.jpg
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: November 13, 2017, 03:44:24 pm »
  • -Receive: 692
« Reply #4 on: November 13, 2017, 04:13:17 pm »
Yeah that is the primary sensor.  Your scan tool doesn't say what the error is specifically.  Short to ground, no signal etc etc.......but it's the heater circuit side of it at fault.  The sensor side is probably OK.   Either way you will need to check the wiring / fuses or replace the sensor if they are OK.
Offline dronners
« Reply #5 on: November 13, 2017, 05:18:52 pm »
i had this code on my old car..  (a fiesta)  it means the heater circuit in the sensors died for some reason or another.  tbh just disturbing an old sensor could of killed it.  it used to cause some slight hesitation on my old car so probably best to get it replaced
Offline Ant b
« Reply #6 on: November 13, 2017, 09:33:36 pm »
I’ve checked all the wiring etc,it was all fine before tho
  • -Receive: 692
« Reply #7 on: November 14, 2017, 10:23:25 am »
Did you disconnect the sensor plug on the bulkhead and turn the probe and harness together as a unit, or did you bind the wires twisting the probe out?
Either way, it's busted.  It may pass a visual inspection, but the ECU is god, and he/she decrees it's f'cked and needs replacing.
Offline Ant b
« Reply #8 on: November 14, 2017, 05:57:41 pm »
Yeah unplugged the harness and twisted togeather,looks like I need a new senser then
