Author Topic: Golf Mk5 strange engine knock  (Read 10585 times)
Offline Mk52017
« on: December 18, 2017, 07:54:04 pm »
Hi I have a 2006 Mk5 gti with the BWA engine. It's developed a strange noise on idle where it sound like a engine knock but goes away for a few seconds and then comes back. The more you rev the car the noise goes away. I've had a new timing chain and tensioner fitted but still have same noise. Any help much appreciated
Offline Raj2212
  • -Given: 75
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115142.0.html
Re: Golf Mk5 strange engine knock
« Reply #1 on: December 18, 2017, 10:19:46 pm »
Does the noise sound more like a rattle ? Or knocking.
No expert but had a similar issue with mine giving off a rattle onced warmed up and idling same BWA engine, had the timing chain and tensioner change, that got rid of the noise for me.  Another part the adjuster is a recommended part to also have changed but costs are £350+ just for the part so I left it out.
It could be that yours has failed. Unless you also had that changed?
Offline Mk52017
« Reply #2 on: December 19, 2017, 01:27:53 pm »
Thanks for the reply. Yeah it sound more like a rattle but I've had the chain and tensioner replaced and the noise is still there. It happens when engine is both cold and warm.
Offline GTi-Tecnix
« Reply #3 on: December 22, 2017, 10:33:28 pm »
Any EM light on dash at all?
Could be rods on oil pump. But can be certain that this could be it.
There are different noises of rattling.
« Last Edit: December 22, 2017, 10:37:17 pm by GTi-Tecnix »
Rapid Acceleration on a Slippery surface
Sounds like a MK5 GTI 💥👊🏽💯
Offline Mk52017
« Reply #4 on: December 23, 2017, 12:02:07 pm »
No EML light on. Would it need to be a new oil pump if it's the rods?
Offline GTi-Tecnix
« Reply #5 on: December 24, 2017, 08:03:19 pm »
If it’s the oil pump then yes because the rod is damaged - watch the YT vid I’ve posted (below). But without having you car checked you won’t know exactly where the knocking is from. It could also be a damaged coil pack because of one is damaged or faulty it will show signs of engine knocking and misfire on one of ther cylinders. It could be a camshaft timing chain and tensioner that can make a rattle noise like a diesel car! If this is the case go for the complete kit i.e chain & tensioner adjuster! But unless you get it checked first you can’t be certain.
« Last Edit: December 24, 2017, 08:06:45 pm by GTi-Tecnix »
