Author Topic: Any thing I should do before stage 1 remap?  (Read 3366 times)
Offline JBOOG
« on: October 28, 2019, 08:17:48 am »
Have just bought a MK 5 2005 with 110k miles. Planning on getting a stage 1 rtech remap.  Are there any maintenance checks or tunes I should get done first, either for  peace of mind or for performance.
Think I need a cam belt and water pump soon so guess that should be done first.
Thank you
  • -Receive: 692
Re: Any thing I should do before stage 1 remap?
« Reply #1 on: November 01, 2019, 01:46:18 pm »
Do a search as it's been covered a million times.
Offline JR.303
« Reply #2 on: November 08, 2019, 07:18:43 am »
Nice previous reply.
I thought forums were somewhere newbies like myself could come for advice.
If you havn't found the info yet try these.
    HPFP CAM FOLLOWER 06D109309R check kist dude
    DIVERTER VALVE  06F145710G
    PCV SYSTEM 06F129101R
    ENGINE OIL 5W 40
    V-POWER OR TESCO 99 FUEL
Thank you
Offline dalerobsonn
« Reply #3 on: November 08, 2019, 09:25:05 am »
Also looking to do this on my 2010 Mk 5 gti, cheers for the above comment  :happy2:
Offline colesey
  • -Receive: 89
« Reply #4 on: November 08, 2019, 09:28:55 am »
You might also want to add their intake / injector / sump clean service for peace of mind.how fresh are the plugs?
Precat delete and panel filter will help you with power and response when you remap.
Offline joe2308
« Reply #5 on: November 09, 2019, 04:43:20 pm »
Definitely the oil pickup pipe, last thing you want is to be choking for oil.
The usual maintenance stuff really - PCV, DV, Cam follower, any other leaks (brake booster hoses are common).
A good scan and making sure the engine is in good health is always nice before putting money into tuning and mods  :smiley:
Offline Bigjimknickers
  • -Given: 55
« Reply #6 on: December 15, 2019, 08:53:11 am »
Just reading into this myself, looks like niki recommends a new fuel pump over 100k too.
Offline colesey
  • -Receive: 89
« Reply #7 on: December 15, 2019, 08:58:23 am »
There can be issues with the seal in the HPFP perishing, which allows petrol to seep into the engine oil. Unfortunately this part is not separately available and needs a new pump at @£200. My car had this issue at 11 years / 25k miles so it is something worth looking out for.
Offline Ricky123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
« Reply #8 on: December 15, 2019, 07:34:44 pm »
As mentioned above...
Latest revision PCV, DV, spark plugs (iridium preferably), oil pick up pipe, HPFP cam follower, oil and filter, air filter, fuel filter too as it’s probably never been changed.
full diagnostic scan to make sure nothing pops up.
Boost leak check
I’d also look at getting the intake valves decoked as it’s made a huge difference to the ones I’ve done in the past.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
