Author Topic: GVKs Scirocco GT TDi  (Read 106807 times)
Offline GVK
  • -Receive: 75
    • GVKmotorsport
Re: GVKs Scirocco GT TDi
« Reply #60 on: September 16, 2025, 12:28:38 am »
Offline GVK
  • -Receive: 75
    • GVKmotorsport
« Reply #61 on: October 10, 2025, 04:09:14 pm »
Stupid electric fuel filler flap has decided to play up, it has not locked in the time I've had the car now it sometimes gets stuck unlocked or locked.  :stupid: :fighting2:
New actuator required, looks a bit of a faff to do as well.
Fitted new fuel flap actuator part from VW £45 + VAT.
Pretty easy to do, torx 20 screw inside the fuel flap then prize the fuel flap and holder out with a plastic trim tool.
Three more torx20 inside the boot to remove the parcel shelf support right hand side to access the wiring plug
Refitting reverse of removal.
Due a service in about 20 days so I fitted a cabin filter and air filter. Need to get it on mates ramp to do the oil and filter etc
Got the rest of the service parts today, Shell Helix Ultra ECT Multi 5W-30 5L engine oil, Bosch fuel and oil filters.
« Last Edit: October 10, 2025, 05:08:21 pm by GVK »
Offline GVK
  • -Receive: 75
    • GVKmotorsport
« Reply #62 on: October 11, 2025, 07:27:35 pm »
Been round an ex-work colleague's place today to change the oil and fuel filters.
Normally I just remove the top lid off the fuel filter and swap the filter but he insisted we remove the whole filter housing so we can drain any water out and clean it out.
Ok fair play I thought... However when it came to leave the car conked out and was just cranking with low fuel pressure fault codes.
We messed around trying to get it to start, ended up 'giving it a sniff' of brake cleaner up the intake which it then fired up into life.
I left on my merry way and struggled to get out of his estate. Pulled into a side road, glow plug light flashing, no power.
Ended up being the fact we'd put 2 of the 4 or 5 fuel pipes that they have in the wrong place on the filter!! Swapped the 2 hoses around, cleared the codes and it started up and ran fine. Doh!
« Last Edit: October 11, 2025, 07:49:31 pm by GVK »
Offline GVK
  • -Receive: 75
    • GVKmotorsport
« Reply #63 on: February 05, 2026, 06:13:27 pm »
Noticed a burning brake smell couple nights ago, passenger wheel was hot to the touch. Driver's side wheel was about 20 degrees on the laser gun, pass. side was over 100 degrees C! New front left caliper fitted from local motor factors (Apec) about £70. Sorted.
Just an intermittent P2015 code to fix now , Inlet manifold runner flaps fault putting the EML on, seen online can get a bracket machined to stop the inlet manifold runner motor over extending giving implausible voltage error.
https://x8r.co.uk/audi-vw-2-0-tdi-a...error-flap-actuator-motor-repair-bracket.html
Offline GVK
  • -Receive: 75
    • GVKmotorsport
« Reply #64 on: February 13, 2026, 08:50:13 pm »
Fitted the repair bracket to the inlet manifold runner motor, it's only 3 TX30 screws,  a lever onto the flaps shaft and a complete PITA spring, luckily you get a spare spring in the kit as that went walkabouts. No wonder the instructions show it being fitted with the manifold off the car as access to that spring is challenging to say the least. Anyway got it done and cleared the code, and no more EML on key on!  :jumpmove:
Offline GVK
  • -Receive: 75
    • GVKmotorsport
« Reply #65 on: Yesterday at 07:04:30 am »
Bought a personal reg from DVLA S10 GVK (S10 = slow ) just waiting for the V750 form so I can assign to car.
Been thinking about getting a plate for about 5 years lol  :signLOL:
