Author Topic: Some Help Broke Down :(  (Read 27918 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Some Help Broke Down :(
« Reply #75 on: September 26, 2023, 09:37:05 am »
Got a price of 264.02 EUROS from the stealers  :surprised:
Head to block bolts    06D103385D   10
Adjuster Bolt   06D109281D   1
Head frame bolts   N10554005   23
Crank pulley bolts   N91143901   6
Timing belt   N90945002   3
   N90628303   2
   N90597005   1
   N91029602   1
   N90596906   1
   N10552402   2
oil pump bolts   WHT000360A   1
   N91149501   3   m7x58
   WHT000006   4   m7x70
   N10430502   1   m7x40
   N91149601   1
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #76 on: September 27, 2023, 06:59:57 pm »
Did a bit more scraping. Are these mating surfaces clean enough?
Did one pass with the honing tool. Hopefully this Is ok  :scared:
Offline LC5F
  • -Receive: 80
« Reply #77 on: September 28, 2023, 03:13:39 am »
Just get a Victor Reinz head bolt kit & Head gasket set.
Timing belt, VW change supplier like shirts - get a kit from continental/gates/Dayco/INA all have been OEM suppliers, whatever kit comes cheapest with water pump
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #78 on: September 30, 2023, 08:04:21 pm »
Had another go at the bores with a different honing tool.
Much happier now.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #79 on: September 30, 2023, 11:24:58 pm »
Looking good  :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #80 on: October 05, 2023, 09:13:26 pm »
Started lapping the valves.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #81 on: October 22, 2023, 11:17:58 am »
Made a tool to remove the exhaust cam sprocket.
Hopefully next week all the parts will arrive
Offline skkane
« Reply #82 on: October 27, 2023, 08:41:35 am »
Set it like that myself. Hopefully timing will be correct when we start it up and check with vcds.
2007 ED30
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #83 on: October 27, 2023, 11:05:52 am »
Something is wrong I cannot get the exhaust cam to tdc mark it will spring forward of back and not stay on it.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #84 on: October 27, 2023, 01:50:42 pm »
I have heard of that happening on the 2.0 TDI motors, but not the TFSI.
Offline RBS
  • -Receive: 49
« Reply #85 on: October 28, 2023, 12:42:40 am »
Just red the whole story…😱 but…
You’re on the right track  :happy2:
Now what I can See on your head…is your intake cam mounted correctly??
The cam locking tool must go in between the spares from the cams… I don’t see the openings in the intake cam?? Or am I wrong??
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #86 on: October 28, 2023, 07:17:34 pm »
 :scared1: I marked the chain correctly but put it one the wrong way round.
I still can't get it to stay at tdc it spins forward or backwards?
Going to buy some new bolts on Monday.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #87 on: October 29, 2023, 07:36:22 pm »
My adjuster is  sitting two teeth furter out. If i take off will it go back to normal?
from video i followed
Mine
« Last Edit: October 30, 2023, 06:42:20 am by dazza »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #88 on: October 31, 2023, 06:47:13 pm »
Mystery solved  :sick:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #89 on: November 01, 2023, 03:16:19 pm »
Pistons are in
