Author Topic: Logs from my car, ed30 conversion  (Read 9613 times)
Offline KRL
  • -Receive: 29
Re: Logs from my car, ed30 conversion
« Reply #15 on: June 29, 2010, 01:25:05 pm »
Ok very strange....
Even though VCDS says you were not WOT your boost graph looks like you were and is not showing spikes.  Also your boost is constantly exceeding specified after the turbo spools:
Are you running the Forge Actuator?
Something is not quite right here as you should not be boosting like that unless you are WOT...
« Last Edit: June 29, 2010, 01:27:28 pm by KRL »
Offline KRL
  • -Receive: 29
« Reply #16 on: June 29, 2010, 01:26:42 pm »
so what figure\'s would you be expecting at 100%?
who knows how to do a throttle alignment?? am willing to travel!
also will this cause the boost spike?
do you think this would need to be re\'aligned after a engine conversion?
TBA taken from RossTech Wiki:
Drive-by-Wire (DBW) Engines using KWP-2000 or CAN
(These are engines WITHOUT a physical cable between the accelerator
and the throttle. Check to see if the engine speaks KWP-2000 or CAN by
looking in the top left of the Open Controller Screen. An example of a
KWP-2000 engine controller is the 2002+ B6 Audi A4 1.8T. Some examples
of CAN engine controllers are the Mk5 Golf 2.0T FSI)
Turn the key on but do not start the car.
    * [Select]
    * [01 - Engine]
    * [Basic Settings - 04]
    * Group 060
    * [Go!]
It should say "Basic Settings: OFF" on the top of your screen.
    * Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen. Once
you do this you will see the top right display say ADP RUN. The TB
adaptation is being done as soon as you switched basic settings on.
You will see the values change and hear the TB cycle for the first few
seconds then it will stop. Leave it in Basic Settings for about 30
seconds.
    * Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
    * Click the [Done, Go Back] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT
running when you do this!
Special Notes
    * In some engines, before doing a TBA, it may be necessary to
cycle the ignition off and back on after clearing faults.
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #17 on: June 29, 2010, 01:30:22 pm »
i dont have VCDS,
Do you think this could be the problem?
Offline PDT
  • -Receive: 142
« Reply #18 on: June 29, 2010, 01:35:02 pm »
Ok very strange....
That boost is extremely low, so ties up with not being at WOT.
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #19 on: June 29, 2010, 01:36:22 pm »
Joe did you and ben doing any runs looking at what the fueling system was doing?
And according to the wiki link that I posted above, if the ECU has been removed or the battery for a prolonged period of time then you need to do a throttle body alignment, also says if the pedals are replaced, and I guess you still have your original pedals so think the alignment would be my first port of call.
Think Darren was offering his VCDS services?  And get some logs as per the APR site so you have all the info you could require.
Offline KRL
  • -Receive: 29
« Reply #20 on: June 29, 2010, 01:40:25 pm »
Ok very strange....
No its not mate - I deducted atmospheric pressure = 1 bar.
Offline PDT
  • -Receive: 142
« Reply #21 on: June 29, 2010, 01:45:00 pm »
that explains things.
Offline joesgti
« Reply #22 on: June 29, 2010, 01:48:33 pm »
think il get morty to do this then, and get some logs.
get my car back tomorrow so will give him a PM.  :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #23 on: June 29, 2010, 01:49:19 pm »
Comparing these graphs to Mike_TFSI http://www.mk5golfgti.co.uk/forum/index.php/topic,15408.0.html which is the only other K04 logs that I can get my ands on (he is running stage 2+ APR the boost is comparable, but mikes show a WOT, but the engine loading on joes is ~140% where as mike, with the supposedly less agressive APR map is showing upto ~190%.
Anyone know what the engine loading value shows?  Could this point to a lack of fuelling for the boost level? as air is nothing without fuel to oxidise?  :smiley:
Offline joesgti
« Reply #24 on: June 29, 2010, 02:14:05 pm »
just had this responce from REVO....
\'Hi Joe,
it looks as though that log is at partial throttle. From the data you can see it’s massively overboosting at lower rpm then is trying to stabilize throughout the rev range. It could be due to any number of things; faulty boost control solenoid, DV, or possibly the actuator not set correctly. To name but a few.
Unfortunately we can only take educated guesses at issues by just looking at data-logs, I’d get it booked into someone that’s used to dealing with engine conversions and the TFSI engine to have it looked at and setup correctly!
Best Regards,
Kev Hall\'
« Reply #25 on: June 29, 2010, 04:42:46 pm »
\'Hi Joe,
Joe thats the best piece of advice youv'e been given mate!  :happy2:
Best Regards,
Kev Hall\'
Offline joesgti
« Reply #26 on: June 29, 2010, 04:44:22 pm »
going to see morty tomorrow night and let him do the throttle, car is booked into statllers on monday. They seem to know what there doing.
« Reply #27 on: June 29, 2010, 04:50:50 pm »
Hope you get it all sorted soon mate, it's probably something stupid!  :happy2:
Offline heavyd
  • -Receive: 29
« Reply #28 on: December 06, 2011, 09:30:59 pm »
Sorry to drag up an old thread, but did you find out what was causing the problem, as my car is doing the same thing
Thanks in advance :wink:
Offline gazbutS3
« Reply #29 on: December 06, 2011, 09:53:04 pm »
IIRC it was the connection into the ECU wasn't correct, the blocks in the plug were pushed back or something, Stattlers sorted for him :happy2:
