Author Topic: Cam Follower Wear at 28k Miles  (Read 8227 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« on: August 10, 2010, 03:34:18 pm »
For one reason or another i actually forgot about doing this since the last change  :surprised: (getting married etc  :smiley:)
I bought 2 cam followers last time so had a spare sat in the Garage. However for the last 28k miles it hasn't been changed  :ashamed:
After a gentle reminder with a thread put on here today linking my tutorial i thought i'd nip out and get mine swapped over.
I took some pics to show what the wear is like on a Mar 2007 TFSi engine. I kept the new one in the pot whilst changing the pics just so i didn't get it dirty.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Cam Follower Wear at 28k Miles
« Reply #1 on: August 10, 2010, 03:36:27 pm »
.........fancy doing mine ?. :grin:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #2 on: August 10, 2010, 03:37:52 pm »
Where are you located?
I don't mind if you want to drive to me  :happy2:
Offline muckipup
  • -Receive: 25
« Reply #3 on: August 10, 2010, 04:31:42 pm »
Quite similar wear pattern to mine after about 15k miles. I'm just not hearing about the 'horror of Autotech HPFP internals' from any source any more but probably won't leave it to 28k myself :wink:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #4 on: August 10, 2010, 04:37:24 pm »
I wouldn't do normally myself Dave and i will be ordering a new one tomorrow so i have a spare.
I just forgot as i haven't been using the car as much and i can't expect the wife to do it  :laugh: :laugh:
Offline KRL
  • -Receive: 29
« Reply #5 on: August 10, 2010, 04:42:03 pm »
This was my follower after around 31k.
Still had plenty of life left in it but I changed it anyway.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #6 on: August 10, 2010, 04:45:58 pm »
This is an extract from an Audi TSB. If you read through it says that the wear indicated by mine and others Cam Followers doesn't need changing. But i always do mine for peace of mind. £25 for new Cam Follower or about £1k for new camshaft. Makes sense to me :smiley:
Offline Lyons
  • -Given: 18
« Reply #7 on: August 10, 2010, 04:50:46 pm »
As I know nothing about engines, can the cam follower actually "go"? Mine is 07 with 26k miles and I'm wondering about doing the belt, pump etc.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #8 on: August 10, 2010, 05:13:45 pm »
It "can" go (as you can see in the pic) but generally on newer engines (late 2006 iirc) there was a revised design of Cam Lobe which improved the problems people were having.
Only reason i check mine so much is because it has done 61k miles, has Autotech HPFP Internals and is at Stage 2+ so i just do it to be safe rather than sorry.
You still have a while yet before your Cambelt & Pump need doing (4yrs and 80k is the norm but VAG keep changing their minds).
I did my Cambelt & Pump at 52K miles purely because of being Stage 2+.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #9 on: August 10, 2010, 07:28:29 pm »
...........Harrogate N Yorks mate. Bet you'r miles away ?.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #10 on: August 10, 2010, 07:32:49 pm »
Can't really get any further as im in Folkestone :sad1:
But follow the tutorial and you can't go far wrong :happy2:
Offline winrya
« Reply #11 on: August 10, 2010, 07:44:30 pm »
I thought it was only the early axx engines which don't suffer this problem?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #12 on: August 10, 2010, 10:29:08 pm »
The earlier engines are more likely to suffer, as Carl said they revised the cam lobe for later cars.
Stu...
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #13 on: August 11, 2010, 07:19:42 am »
........typical  :signLOL:. But thanks for that.
Offline winrya
« Reply #14 on: August 11, 2010, 09:06:23 pm »
Done a bit of digging on this and info on almost all sites say axx isn't affected, it was only from 2006 onwards the problem started.  I remember joegti had his checked recently and had no wear at all on a 2005 engine?!
