June 21, 2026, 10:43:14 pm
All Things Mk5
Sat Nav and Car Audio
Help needed coding rns510 and highline
Topic: Help needed coding rns510 and highline (Read 5254 times)
PDT
Just look at my post count
-Given: 3
-Receive: 142
February 04, 2011, 06:33:20 pm »
Fitted my RNS510 today, all works except 2 things:
On mfsw the up/down buttons dont cycle through stations or tracks
The highline doesnt show any nav or audio options.
Volume, mute etc on the mfsw work perfectly. Any ideas?
182_blue
Global Moderator
-Given: 20
-Receive: 54
Re: Help needed coding rns510 and highline
Reply #1 on:
February 04, 2011, 06:41:45 pm »
What coding have you done ?
PDT
-Given: 3
-Receive: 142
Reply #2 on:
February 04, 2011, 07:00:57 pm »
Nothing yet
182_blue
Global Moderator
-Given: 20
-Receive: 54
Reply #3 on:
February 04, 2011, 07:16:48 pm »
That will be the problem then
vRStu
-Given: 90
-Receive: 159
Reply #4 on:
February 04, 2011, 08:20:29 pm »
......... and you expect people to trust you to flash their ECU
Stu...
Hedge
-Given: 484
-Receive: 304
Reply #5 on:
February 04, 2011, 08:48:00 pm »
Quote from: vRStu on February 04, 2011, 08:20:29 pm
kevinm
Always Involved
-Given: 13
-Receive: 25
No. 728
Reply #6 on:
February 04, 2011, 08:51:51 pm »
After I coded the RNS510, I had to reboot it to show up on the highline.
http://www.mk5golfgti.co.uk/forum/index.php/topic,68916.msg748356.html#msg748356
PDT
-Given: 3
-Receive: 142
Reply #7 on:
February 04, 2011, 10:44:32 pm »
I can code, repair and clone most O.E ECU's, fit aftermarket engine management, I have even built many custom made aftermarket ECU systems and we are busy working on some mapping for a car thats in this years BTCC, so ECU mapping isnt a problem.
However getting my highline system working again is baffling me
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #8 on:
February 04, 2011, 10:59:37 pm »
Have you enabled Navigation in the installations list.
https://www.justgiving.com/thenational3peaks
PDT
-Given: 3
-Receive: 142
Reply #9 on:
February 04, 2011, 11:00:55 pm »
Not done anything yet, will maybe have a go tomorrow if I get 5 mins. Where will I find the installations list in vcds?
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #10 on:
February 04, 2011, 11:04:52 pm »
Open VCDS, click on 19 Can Gateway, and select the installation button. That should throw up a list of installed features, and youll need to click number 37 - Navigation
vRS Carl
-Given: 282
-Receive: 241
I'm the F.A.G (Forum Apple Guru)
Reply #11 on:
February 04, 2011, 11:06:50 pm »
Go into block 19 - Can-Gateway and tick 37 - Navigation
Once that is done you then need to go into block 37 - Navigation and code it to get it to work with highline.
Hardly rocket science and I haven't done any ECU coding for cars in the BTCC or anything else for that matter
PDT
-Given: 3
-Receive: 142
Reply #12 on:
February 04, 2011, 11:17:43 pm »
Thanks richwig
Carl, he beat you to it
vRS Carl
-Given: 282
-Receive: 241
Reply #13 on:
February 04, 2011, 11:22:11 pm »
My explanation was better though as i reminded you to code the RNS too.
I'm branching out in to Mapping now. If you can map cars but not know how to use VCDS then I will sh*t hot at mapping as i can use VCDS
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Reply #14 on:
February 04, 2011, 11:26:21 pm »
All Things Mk5
