Author Topic: What did you and your MKV do today?  (Read 3566226 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #120 on: July 15, 2011, 02:26:10 pm »
I mananged 44.1 mpg on the drive to work! :pomppomp:
Diesel Daily Hack.
« Reply #121 on: July 15, 2011, 02:29:09 pm »
Only a bit for now.  When my magnets arrive its velcro off and wrap the section behind the number plate gloss black too  :party:
Couldnt wait for the magnets to come so had the rest wrapped today, not 100 happy with it though looks a different black  :fighting:
The bottom lip is glossy black matching my Roof / pillars / wing mirrors, the new vinyl doesnt look as shiny :(
[/quote]
Offline scotta
  • Edition 30
« Reply #122 on: July 15, 2011, 06:57:35 pm »
[/quote]
Where are you getting the vinyl from? Considering doing the front grill on the audi.
« Reply #123 on: July 15, 2011, 07:00:37 pm »
Local signwriters, they do quite a bit of vehicle stuff 30 euros for both bits done in 3M vinyl  :happy2:
« Reply #124 on: July 16, 2011, 07:53:15 am »
This morning I will mostly be reading Cam Follower tutorials (and looking at StevePs project  :evilgrin:).  Had no bother last time but reading MJRs nightmare with stripped threads and needing a new HPFP I need to be extra careful as Im due to drive to UK!
« Reply #125 on: July 16, 2011, 09:48:47 am »
Try and get the alloys changed over back to Pescaras. If the weather was decent, I'd strip the Monzas' protection down and reseal them up before storage.
« Reply #126 on: July 16, 2011, 12:06:54 pm »
Took half hour found some possible cause for concern  :sad1: http://www.mk5golfgti.co.uk/forum/index.php/topic,32327.msg398863.html#msg398863
After 15k miles or thereabouts...
« Last Edit: July 16, 2011, 02:42:37 pm by Tfsi_Mike »
Offline Little_Dave
« Reply #127 on: July 16, 2011, 12:40:54 pm »
Fitted my new plates on the car using autohaus plate surrounds  :wink: rear one was a piece of cake but front was more tricky, had to remove standard plate mount and lost some of the plastic push thru screw bits in the grill  :signLOL: ended up removing the grill which i should've done in the first place  :stupid: tipping it down outside now so no chance of some pics  :sad1:
Dave
« Reply #128 on: July 16, 2011, 02:22:48 pm »
Added a Cupra badge to the interior for when Im not on the St2+ map, so I dont forget what Im driving  :grin:
« Reply #129 on: July 16, 2011, 04:23:10 pm »
Did a vcds log and came up with a lot of errors.  :sad1:
New coilpacks for a start.  :sad:
« Reply #130 on: July 16, 2011, 11:23:14 pm »
Washed my car and realised its taking a battering from motorway miles!  :sad1:
Offline ukdub
« Reply #131 on: July 17, 2011, 12:14:00 am »
Had a K04 fitted and then did my best ever MPG run on the way to work lol 39.6mpg.  :happy2: :laugh:
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline GLIDN
« Reply #132 on: July 17, 2011, 04:08:56 am »
Tuesday Night just passed, Fitted RCD310 Plus Dash mount MDI Kit (Thanks to Demon666)
Install new Spark Plugs and Stage 1 BSH PCV kit.
Yesterday Saturday, Did an Oil Change on my GTI install APR Rear Anti-swaybar. What an awesome upgrade.
Today, Installing a New Can-Gateway from 1K0 907 530 E to a 1K0 907 530 AD.
http://www.mk5golfgti.co.uk/forum/index.php/topic,32352.0.html
However having issue's with coding. But no errors
Will update link once I'm finished doing original issue's.
« Last Edit: July 17, 2011, 05:20:06 am by GLIDN »
Offline gulfstream11
« Reply #133 on: July 17, 2011, 07:28:01 pm »
Got busy with the trolley jack..Loads of tar spots inside the wheels...Done!
« Reply #134 on: July 18, 2011, 12:55:09 pm »
Id eat my din dins off those!  :signLOL:
