Author Topic: What did you and your MKV do today?  (Read 3941430 times)
Offline ZoliWorks
« Reply #12885 on: Today at 12:12:54 am »
My GTI has the 10 speaker audio system not the usual 8, and the drivers side Mid was not always working unless the volume was cranked up.....then it came alive.
It was not the wiring to the door as that must be fine as the tweeter and bass speakers were fine.
The Mid speaker was fine as all were replaced a couple of years ago so as a last resort I decided to swap out the factory crossover (the 10 wire, triangular module that the door have) and it worked
I have full sound now and it also sounds better, so the original must have failed.
Do you have an amplifier? Also what year is the car again? I have an amp, 10 speaker kit, it's 2006 and I dont have this crossover. I always wondered what part goes where those 3 screw holes are. Now I know
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline mjmallia
  • -Receive: 60
« Reply #12886 on: Today at 08:26:28 am »
Not sure to be honest.  I have the RCD510 DAB, these crossovers in the front door with 3 speakers......then rear doors with 2 in each.
My GTI is a late 2005
« Last Edit: Today at 08:32:47 am by mjmallia »
Mike
South Coast
