Author Topic: Weight saving whores - Lightweight Batteries *discount content!*  (Read 37471 times)
Offline david25
  • -Given: 19
Re: Weight saving whores - Lightweight Batteries *discount content!*
« Reply #60 on: September 05, 2011, 08:59:49 am »
My fat battery is a 70 Ah type as well while I know A3 2.0 TFSIs just having 60 Ah.
Keep in mind ''Amp hours'' isn't the one and only. ''Cranking Amps'' is even more
important ro start an engine.
So if you don't listen to music while the engine isn't running I don't see any issue
reducing the Amp Hours radically.
This guy (USA) had a 60ah Varta from the factory (and only 480a)
http://www.golfmkv.com/forums/showthread.php?t=136015
« Last Edit: September 06, 2011, 07:14:20 pm by david25 »
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #61 on: September 05, 2011, 06:07:01 pm »
Wrong link, David?
60 Ah is way more above minimum.
If you are careful 25 - 30 Ah should start every day.
"You get what you pay for."
« Reply #62 on: September 05, 2011, 06:09:03 pm »
15AH here  :ashamed:  Am careful and starts every day
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #63 on: September 05, 2011, 07:39:01 pm »
No doubt, Mike.  :wink:
But I wanted to be careful as well. Careful to recommend.
A Braille offers much higher crank amps than conventional batteries
and I kept in mind technically non skilled people reading this. So
better have some reserve.
 :smiley:
« Reply #64 on: September 05, 2011, 07:41:34 pm »
 :smiley:
Helpful and accurate as ever  :wink:
I didnt leave the CTEK charger in the car when I dropped it at the dealers, I might drop it off tommorow after work as it will probably be sat in the body shop for a week of 2  :sad1: :sad1:
Offline david25
  • -Given: 19
« Reply #65 on: September 06, 2011, 07:14:09 pm »
Wrong link, David?
Opps, let's try again:
Offline Janner_Sy
  • -Receive: 113
« Reply #66 on: October 25, 2011, 07:18:06 pm »
Anyone suffer with flat batteries then?
« Reply #67 on: October 25, 2011, 07:19:47 pm »
Thought id find you here :p
After 4.5 - 5 days it didnt have enought juice to crank over.
Ive got an out door extension run outside the house with CTEK conditioner charger keeping it topped up.  If you dont use the car much could use it just for 1/4 miles and track days?
Offline Janner_Sy
  • -Receive: 113
« Reply #68 on: October 25, 2011, 07:22:45 pm »
4-5 days isn't ideal tbh, plus my car is parked about 30m from the house sometimes for 4 days+ without use
Interesting idea for the spare battery though
Offline Blade
  • Taking a sabatical from cars
« Reply #69 on: October 25, 2011, 07:49:42 pm »
Mine has been left for 3 weeks or more and started 1st time?
« Reply #70 on: October 25, 2011, 07:51:01 pm »
Might give it a test  :happy2:  was 5 days and didnt start but Dont think Id fully charge it prior due to being giddy and inpaitient lol
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #71 on: November 04, 2011, 12:54:00 pm »
Found this:
As far as I know - All the CCA for the manufacturers is done at 0F, and the CA is at 32F, all this info is off the manufacturer website.
Acording to Autozone website the 240sx needs 360 CA.
So if you want 100% factory reliability even at 0F you want to be shoping around for something that will have at least 360CCA.
For those of you where the weather gets in the negative digits (F) you will want somethign that has a CCA > 360 at 0F
The battery I had in (Advance Auto Parts stock replacement stuff) weights 37lb..
READ THIS:
In BLUE are the brands whose CCA Ratings seems either off or make it hard to find their testing methods.
Deka Batteries are more than likely to be Deka ETX rebadged -- Their advirtised CCA IS PROBABLY NOT PERFOMED AT 0F.
By Brand:
Braille**:
Braille B3121 ----------CCA: 550 ---- weight: 21lb ---------------- CA: 742
Braille B2015 ----------CCA: 425 ---- weight: 15lb ---------------- CA: 574
Braille B14115 ---------CCA: 360 ---- weight: 11lb,8oz ------------ CA: 486
Braille B106 -----------CCA: 210 ---- weight: 6lb,6oz ------------- CA: 283
Westco:
Westco Miata ---------CCA: 475 ---- weight: 25lb
Deka:
Deka ETX30 -----------CCA: 370 ---- weight: 21.7lb
Deka ETX20 -----------CCA: 270 ---- weight: 15.5lb
Deka ETX18 -----------CCA: 300 ---- weight: 18lb
Deka ETX16 -----------CCA: 275 ---- weight: 17lb
Deka ETX14 -----------CCA: 200 ---- weight: 12lb
Deka ETX12 -----------CCA: 180 ---- weight: 9.4lb
Deka ETX9 -----------CCA: 120 ---- weight: 6.3lb
Odyssey:
Odyssey PC680 --------CCA: 220 --- weight: 15lb / 16lb For MJT*
Odyssey PC925/MJT ---CCA: 380 --- weight: 24lb / 26lb For MJT*
Optima:
Optima 34&34R --------CCA 800 -----weight: 37.9lb --------------- CA: 1000
Optima 37/78 ----------CCA 800 ---- weight: 38.8lb --------------- CA: 1000
Optima 75/25 ----------CCA 720 ---- weight: 33.1lb --------------- CA: 910
Optima 25&35 ---------CCA 720 ----- weight: 31.7lb --------------- CA: 910
Duralast:
Duralast 8AMU1R ------CCA: 330 ---- weight: 25lb
Marathon:
Marathon MAR-8AMU1R-CCA: 320 ---- weight: 25lb
By CCA:
Optima 34&34R --------CCA 800 -----weight: 37.9lb -------------- CA: 1000
Optima 37/78 ----------CCA 800 ---- weight: 38.8lb -------------- CA: 1000
Optima 75/25 ----------CCA 720 ---- weight: 33.1lb -------------- CA: 910
Optima 25&35 ---------CCA 720 ----- weight: 31.7lb -------------- CA: 910
Odyssey PC925/MJT ---CCA: 380 ---- weight: 24lb / 26lb For MJT*
Odyssey PC680 --------CCA: 220 ---- weight: 15lb / 16lb For MJT*
By Weight:
More info:
Braile:
Probably Deka rebadged
**no info on website on what Temp the CCA and CA test are done at...
DEKA:
Come with M6 Thread on terminals - you will need adapter to SAE automotive Terminals.
Rebadged as BigCrank, Braille and other brands // BigCrank has cheap price .
(Proved and discussed on the vwvortex there is a whole thread about it.)
Odyssey:
*MJT: Metal Jacket + Terminals.
Also the Odysseys have battery mounting brakets avaible.
Miata Battery:
Duralast rates them at 330CCA, Marathon at 320CCA, Westco at 475CCA,
make what you want of this info but personally I'm not getting a Westco Battery
Made by EastPenn Mfg.
Sold under:
Marathon MAR-8AMU1R (1Year Warranty)
Westco 12V31M (4 Year Warranty)
Duralast 8AMU1R (8Year Warranty - apparently WAS avaible at autozone)
Offline Tamiyoman
  • -Receive: 39
« Reply #72 on: November 05, 2011, 12:12:50 am »
Surely it wont be long before Lipo battery prices come down to a reasonable level and our batteries then weigh about 1.5Kg  :drinking:
« Reply #73 on: November 05, 2011, 12:16:03 am »
 :party: my dads got a fortune in lypo cells for some of his rc truggys  :driver:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #74 on: November 05, 2011, 12:41:52 am »
You forgot to say ''.... and deliver 100 Ah + 1000 CCA''.  :grin:
