Author Topic: Can Gateway battery drain  (Read 2827 times)
Offline AlanEdition30
« on: September 30, 2011, 06:43:52 pm »
Hi
For people who have had the dreaded battery drain from installing a 3rd generation headunit (RNS 510). How quickly did you battery go flat, as im just making sure i definitely need one?
Since having the latest RNS 510 firmware put on for the rear view camera install, my car is still not showing any signs of a battery going flat despite leaving it for 48 once and 72 hours once as well, it turns over on the key as fast as ever  :laugh:
The gateway I have is K
Address 19: CAN Gateway        Labels: None
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 241106F2000049
   Coding: 3F0F034807000001
   Shop #: WSC 00218 210 82609
   VCID: 2F691568C78D
No fault code found.
Can anybody shed anymore light on whether im guaranteed battery drain in the not so distant future?
Am i not leaving the car long enough to have a flat battery?
Confused.....  :laugh:  :scared:
Offline vRS_Pagey
  • -Receive: 59
Re: Can Gateway battery drain
« Reply #1 on: September 30, 2011, 06:48:55 pm »
Battery drain will normally occur over night, I'm surprised that you are suffering this, as I have known a few people with rev 'K' that have been fine..... :surprised:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #2 on: September 30, 2011, 06:50:02 pm »
I think Some K gateways get away with not having the battery drain issue, sure someone with more knowledge then me will be along to confirm
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #3 on: September 30, 2011, 07:15:08 pm »
Guys, if you read the OP, you'll see that he's not suffering battery drain, but wondering if it is going to present in the future.
I'd say you'll be fine, Alan :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #4 on: September 30, 2011, 08:20:15 pm »
I must learn to read the entire post....... :laugh:
Yup, with rev 'K' you should be cool.
