Author Topic: most Cost effective Brake upgrade?  (Read 10900 times)
Offline duncan
« on: April 03, 2009, 12:39:12 pm »
am considering getting my brakes upgraded now that the car is mapped, dont feel like the standard ones are quite up to it
would really want to spend a max of 1k and dont have any intentions of going to stage 2.
what would be the best option - get the front brake set from a cupra or R32? or would i need to get bigger pot calipers?
Candy white GTI, MRC tuning Remap - the rest will remain standard...
Offline WhiteGTI
  • F-A-S-T
Re: most Cost effective Brake upgrade?
« Reply #1 on: April 03, 2009, 12:49:29 pm »
Lol....you say that now, but I guarantee you will end up doing it at some point!! Such is the way with modifying, and this forum is a really bad influence!  :grin: :grin: :grin: :grin:
2006 E46 BMW M3 - 343hp
Offline duncan
« Reply #2 on: April 03, 2009, 12:55:02 pm »
to be honest - i would get a WALK kit, big brakes and LSD before i go near stage 2, and only then would i do it if the insurance wasnt a complete joke.
as it stands am the most broke ive been in 5 years after spending money i dont have on a remap and other bits and pieces on the car so will be a while before i can afford it and ive still got a long time before ill get bored of the performance!
« Reply #3 on: April 03, 2009, 10:19:44 pm »
In that case you need to update your sig :signLOL:
Offline keith
« Reply #4 on: April 03, 2009, 10:50:10 pm »
Its a popular question on here, but what do you do with your car?
track days, 1/4 mile.Or just fast road use, if its the later then 1k on a big brake set up is a waste of money the r32 would do you fine at about £500.
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #5 on: April 03, 2009, 10:53:57 pm »
How are the R32 brakes different from the stock GTi ones?
Are they larger?  Have larger calipers/pots?
« Reply #6 on: April 03, 2009, 11:21:26 pm »
Bigger (345mm) discs and calipers I am led to believe.
  • MUBster DUBster
« Reply #7 on: April 03, 2009, 11:51:53 pm »
Are they straight replacements, or are changes required...?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #8 on: April 04, 2009, 12:03:49 am »
Fronts are a straight bolt on (if you buy all the correct parts), rears need some small modification to the splash guards IIRC  :happy2:
  • MUBster DUBster
« Reply #9 on: April 04, 2009, 09:00:48 am »
Anyoen know of a fitting guide I can glance through before I commit to yet another mod?
Look at me...thinking about spending more time and money...  :evilgrin:
P.S.  I don't want the calipers to be blue...can you get them in red (or will I have to paint them)?
Offline icenutter
« Reply #10 on: April 04, 2009, 09:52:32 am »
'scuse my ignorance; what is a WALK kit?
Get all your sports nutrition products here; http://www.myprotein.co.uk and use the code MP73153 to get 5% off your first order.
« Reply #11 on: April 04, 2009, 09:59:21 am »
If you get the Leon Cupra R braked they are identical to R32 ones but have Red calipers  :happy2:
Offline QD MBE
  • -Receive: 102
« Reply #13 on: April 04, 2009, 10:15:29 am »
They really are very easy to fit, the fronts are a virtually direct replacement, all you need are the Splash guards, discs, calipers, pads, carriers, and brake lines.
The rears are even easier, Discs, carriers, are all you will need, the splash guards can be reused (with some slight tweaks) and the pads and lines are the same.
Rear how to
http://worldimpex.com/assets/partdocuments/DIY_Rear_310mm_R32-1.pdf
http://www.mk5golfgti.co.uk/forum/index.php?topic=995.75
Can't find anything as yet.  But it really is so easy
Offline luca
« Reply #14 on: April 04, 2009, 10:34:24 am »
I have the leon cupra fronts on mine. Plenty of stopping power, you could even put ferodo ds2500 pads front and rear with that setup and you would still have around £250 change from £1k :happy2:
The brakes fill the alloys nicely too
