Author Topic: Xenon headlight's misting up!  (Read 4879 times)
Offline sanj
  • -Given: 17
« on: January 07, 2012, 05:41:14 pm »
Do any other member's have a build up of moisture inside the headlight's when it rain's?Is this normal on GTI's with xenon's?Headlight's seem to be water tight but am I right in thinking the xenon's have some sort of breather hole somewhere? :surprised:
Offline vRS_Pagey
  • -Receive: 59
Re: Xenon headlight's misting up!
« Reply #1 on: January 07, 2012, 06:43:55 pm »
I have none xenons but the housing is the same and they mist up, seems a common occurence on the MK5.  Some members have suggested putting a couple of the gel silca bags in the headlight which I plan on trying, cheap enough to get off egay!  :pomppomp:
Offline apples12
« Reply #2 on: January 07, 2012, 06:45:19 pm »
shouldnt be misting up!
check that the main beam plastic cover is securely on then check that both rubber covers are in place
just below the main beam cover there SHOULD be a little tiny plastic moulded 4mm nut...if thats in place then thats all good, if it isnt (means its been removed to gain access to replace the adjuster motor) then there'll be a hole there about 10mm in diameter, VW do a 'plug' that you can buy that fits in that hole, ive had to buy one to fit in there as i was curious if that was a real nut or a plastic moulding.lol
otherwise...you've got cracked lights dude....
good luck with finding the leak.... :happy2:
MK6 GT TDI  - CW - LUX pack
GONE
Offline sanj
  • -Given: 17
« Reply #3 on: January 07, 2012, 08:24:42 pm »
Thank's for the replie's guy's,there was a lot less condensation today and it was on both headlight's(at the bottom and in the same place on both) which lead's me to believe that they may have been left somewhere damp when they were not in use and now fitted may take a few day's to settle down,I hope so! :smiley:
Offline Gez G
« Reply #4 on: January 07, 2012, 09:37:50 pm »
My non xenon headlights do this a bit too keep meaning to try the silica gel to see if it is effective.
Offline Boothy
« Reply #5 on: January 07, 2012, 09:55:00 pm »
My xenons also do it. In the past I've run the lights on permanent l for a long journey and left the cover off of the rear and that seemed to dry them out for a bit button always returns.
Offline Russ_leeds
« Reply #6 on: January 07, 2012, 11:34:48 pm »
yeah my non xenon lights do this, i tried to get them changed at the dealers under warranty but they said as long as it went it was ok :signLOL:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline sanj
  • -Given: 17
« Reply #7 on: January 08, 2012, 01:35:55 pm »
Look's like it's not just me then!I'm sure the headlight's are'nt completely sealed as my original GTI set had a small dead spider in one of them and my previous Mercedes has a wasp in one!It's been ok today as it's not raining so I blew hot air into them using my daughter's hair dryer and put a little vasaline onto the rubber cover's and onto the headlight adjuster's(small white screw's) just in case,i'll see how they get on as i'm sure mine were getting condensation as they were damp while in storage and when used for the first time the heat off the xenon caused the problem I had,I work for a computer retailer so we get plenty if not hundred's of the silca gel pack's with computer component's and i'll offer any member on here 4 small pack's if you can send me a stamped addressed envelope!PM me if you need me address! :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #8 on: January 08, 2012, 01:54:25 pm »
They aren't fully sealed - they have vents so they can breathe as the atmospheric pressure requires this.
Silica gel bags will greatly help the problem. Ive got two big ones in mine and its sorted it. You just have to dry them out every 6 months.
