Author Topic: MK5 GTI - Disappointing Revo Stage 2 Results?  (Read 22399 times)
Offline KC_Gti
« on: February 20, 2012, 06:23:02 pm »
Hi Guys/Gals
Hope someone can shed some light on this situation for me  :sad1:
Had the car in with Awesome GTI today to have a Revo stage 2 map uploaded. Current setup on the car at the moment includes an ITG induction, Revision D divertor valve and a BCS TBE (200 cel). Car runs on V-power only. Dyno's from stock -> Stage 1 -> Stage 2
Stock
Stage 1 B6:F8:T2
Stage 2 B:8:F9:T3
Now I know a stage 1 to stage 2 isn't as different between going from stock to stage 1. But is no increase in BHP normal?  :confused:
« Last Edit: February 20, 2012, 08:46:04 pm by KC_Gti »
Re: Disappointing Revo Stage 2 Results?
« Reply #1 on: February 20, 2012, 06:35:56 pm »
I presume that this is a 200PS GTI. From what i can remember, Tony_Danza ran stage 2 on his GTI and it made about 270bhp.
Offline PDT
  • -Receive: 142
« Reply #2 on: February 20, 2012, 06:41:52 pm »
Stg2 will usually see 265-270hp and 270-290 ftlb.
Torque figures Seem massive compared to other dyno results, not unusual though. Timing numbers seem low, would expect timing of 4-5 quite easily.
Looks like torque drops a lot at 3500rpm and at 4000rpm the power flattens off.
Offline KC_Gti
« Reply #3 on: February 20, 2012, 08:45:36 pm »
Thanks for the replies guys.
Good to know that the bhp is resonable. guys at Awesome did indicate a very low timing but wasn't able to tell me exactly why it has happened. I've tried V.Power from a different garage this time, thinking it could be bad batch of fuel from the local. Knocking was experienced with any timing over 3 hence why its set so low. Any ideas of the cause or what to look out for?
As for the torque being so high and flattening out so quickly, is this down to the setting applied or is it another sign of a problem?  :sad1:
Offline ukdub
« Reply #4 on: February 20, 2012, 10:21:33 pm »
It could be a bad or 'off' batch of V power.  Most cars run on V power will be at timing 5-6.  Saying that, you still made good power for stage 2  :happy2:  I remember my car being set up by Awesome when I went stage 2 (K03) and I was running 9-6-9 with no timing knock at all running on V power (Im sure BHP was the same).  Im presently running 9-6-6 (K04) upgrade still with no knock on V power.  As for the high torque figure, a few people have questioned Awesomes torque figures, but to be honest, use a dyno as a tuning tool.  Keep using the same dyno throughout all your upgrades to make a comparison on said upgrades. :smiley:
Im sure after a few tank fulls of V power from a different Shell and you asking nicely, they will run your car again on the RR.
BTW I was there this morning, you car looks sweet  :happy2:
Looks like you have gained 40 ft-lbs of torque wheather the reading is high or not from your stage 1 graph
« Last Edit: February 20, 2012, 10:26:26 pm by ukdub »
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Re: MK5 GTI - Disappointing Revo Stage 2 Results?
« Reply #5 on: February 20, 2012, 10:59:30 pm »
....That's exactly the range which my Mk5 GTI Revo Stage 2 dyno's at - With the help of a Forge Twintake. (Dyno-Dynamics rollers @ JKM)
Offline PDT
  • -Receive: 142
« Reply #6 on: February 21, 2012, 12:09:59 am »
Theres a good reason why most serious tuners want / have a dyno dynamics dyno.  :wink:
Repeatable results and accuracy cant be matched by any other tuning dyno manufacturer.
Offline ukdub
« Reply #7 on: February 21, 2012, 12:18:47 am »
All dynos can be accuracte if used alone to gauge upgrades.   :happy2:
Multible RR results from different dynos should be taken with a pinch of salt.  It shouldnt be that way, but alas, it is  :drinking:
« Last Edit: February 21, 2012, 12:22:19 am by ukdub »
Offline KC_Gti
« Reply #8 on: February 21, 2012, 01:41:14 pm »
Thanks for the replies guys. Appreciate it. UKDUB remember seeing your car about, looking cool  :happy2:
I guess the only thing to do at this stage is to get a few data logged runs with VCDS. Is there a particular block I should be looking at to identify problems with the timing?
Offline PDT
  • -Receive: 142
« Reply #9 on: February 21, 2012, 02:22:04 pm »
block 020 shows actual timing pull. this is a good place to start.
Offline KC_Gti
« Reply #10 on: February 21, 2012, 09:04:29 pm »
Thanks PDT. I will start with looking at that  :happy2:
Offline KC_Gti
Re: MK5 GTI 200PS - Disappointing Revo Stage 2 Results?
« Reply #11 on: March 22, 2012, 01:06:26 pm »
Right guys. Did a couple of runs yesterday to try and figure out reason for poor timing. This is what I got. Being a total n00b at this, would appreciate any feedback on this. Thanks  :happy2:
Run 1
Run 2
« Reply #12 on: March 22, 2012, 01:21:59 pm »
IMO you logs look ok with a good max intake mass.
What setting are you using?
Offline KC_Gti
« Reply #13 on: March 22, 2012, 01:26:03 pm »
Thanks for the reply Bacillus, current setting is B:8:F9:T3.
« Reply #14 on: March 22, 2012, 01:33:47 pm »
Personally I would try T4 as you have no CFs for most of your run and see what the log looks like.
Just to be clear, are you using 98/99 octane fuel?
