Author Topic: Vinyl Wrapping  (Read 6522 times)
Offline zenicman9
Vinyl Wrapping
« on: June 18, 2012, 04:08:10 pm »
Hi
Can anyone wrap on this forum? I am looking to get my 2 wing mirrors wrapped
Saintsteve
Re: Vinyl Wrapping
« Reply #1 on: June 18, 2012, 05:54:37 pm »
Get them sprayed,wrap un-peals itself after a while as its over stretched to form the curves etc.Did the same with carbon wrap, and it was a totally waste of time n effort.
Replacement covers and get them sprayed and keep your oem ones spare in case you revert to stock is the way to go.
Offline callis
Re: Vinyl Wrapping
« Reply #2 on: June 18, 2012, 07:20:27 pm »
My rear bumper lower section, and side skirts have been wrapped by the previous owner and has started to peel off. Better to get em painted tbh.
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Re: Vinyl Wrapping
« Reply #3 on: June 18, 2012, 07:37:48 pm »
Wrapping wing mirrors is a knob of a job...  :fighting:
Ryy
Re: Vinyl Wrapping
« Reply #4 on: June 18, 2012, 10:25:26 pm »
Just had mine done on the Scirocco @ Chameleon in Daventry. Well happy with the job too :)
PSW
Re: Vinyl Wrapping
« Reply #5 on: June 18, 2012, 10:52:46 pm »
Trouble is with wing mirrors is that the weave has to be pulled in about 4directions so not good.... As Steve said above get a spare set or hold out for some osir carbon jobbies  :happy2:
Offline Rocket
  • On the hunt for my first GTI
    • Carbon fibre skins from vinyls to parts
Re: Vinyl Wrapping
« Reply #6 on: June 18, 2012, 11:43:48 pm »
I can wrap them if you wanted, but as mentioned by others, if it was the carbon weave you wanted then its harder work but can be done. If its only a solid colour change you want, this could be easier. Any thoughts op?
Offline zenicman9
Re: Vinyl Wrapping
« Reply #7 on: June 19, 2012, 08:58:09 am »
I just want them gloss black tbf
Re: Vinyl Wrapping
« Reply #8 on: June 21, 2012, 01:52:23 pm »
As above, don't bother wrapping them,  but some others then they can just be swapped over, a 2 minute job!
Bought these from fleebay, non OEM but great and with the correct code (L041) for VW Solid Gloss Black. Oh and only £50 so silly cheap! :smiley:
http://www.ebay.co.uk/itm/GLOSS-BLACK-Wing-Mirror-Cover-VW-Golf-MK5-Passat-B6-Jetta-EOS-Right-Driver-Side-/360456671232?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53ece45000#ht_1645wt_689
http://www.ebay.co.uk/itm/GLOSS-BLACK-Wing-Mirror-Cover-VW-Golf-MK5-Passat-B6-Jetta-Left-Passenger-Side-/170838387649?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27c6c2ebc1#ht_1645wt_689
The ones I got!!   :happy2:
Beaven_25
Re: Vinyl Wrapping
« Reply #9 on: May 26, 2017, 11:22:33 am »
I had tried wrapping wing mirrors but couldn’t get success it but now I have changed my mind and will get full body vehicle wraps for my car but for this I would like to hire some professional service as I just can’t bear to see any damage to my favorite car.
willni
Re: Vinyl Wrapping
« Reply #10 on: May 27, 2017, 07:16:35 pm »
If you want wrap to work, hire a professional or order pre-cut pieces. Ebay wrap etc will peel because the glue is low quality and weak, with professional wrap it stays on for until you want to remove, it heals any rips and tears in it.
With wingmirrors it's easier to hire someone, you won't get the curves. and it will only take them 5 minutes.
