Author Topic: *****Scopes RS GTI*****  (Read 192440 times)
Re: Scopes Reflex Silver GTI with "Carbon Bits added"
« Reply #315 on: May 24, 2014, 12:43:35 pm »
The SP ball joints are a great little mod  :smiley:
Offline SurreyED30
« Reply #316 on: May 24, 2014, 01:22:06 pm »
Hoping to be fully super pro bushed / parts by the end of the year so looking at £1500 fitted
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #317 on: May 24, 2014, 10:14:55 pm »
Can't wait to get my mounts on, I only put my oem mk5 new top mounts in 2300 miles ago so when I sell the suspension set up in 2 weeks time they'll be perfect for someone  :happy2:
I just like to replace everything  :drool:
I had a irritating rattle which turned out to be the bolt that holds in inner fuse box (drivers side) in place. now the only rattle I have is the passenger side sun visor bulb housing rattles which drivers me nuts when pulling away/reversing  :fighting:
Discs or the bells ?
Jake
Jake
Yes Jake, Great Idea! I hadn't long changed my OEM top mounts, they made a difference then... But the difference now is great, again that's with a few mods done, with new Tracking/Alignment settings..  :driver:
 :driver: Car is running great !  :star:
We all like to change things, its always for the better though !
My rattle, sounds more like a tapping sound, I have checked the fuse box and loads of other places, but it seems to be more from the outside, but in behind my dash at the same time... Maybe I'll take the scuttle panel off and have a look in around there... :confused:
I give the Rear bells a lick of paint, they had went a bit rusty, so cleaned up for now.
If the Rear ARB was all dried up, how would the car perform?  Being so stiff like that?
 I had bouncy suspension, but it all seems good now, since it got lube'd up
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #318 on: May 24, 2014, 10:22:32 pm »
Let us know what u think of the superpro balljoints as I'm thinking of doing it too..
[/quote]
I had already had the superpro ball joints, they got replaced... They allow for extra camber, I had to bring the camber back in as it was wearing the insides of my tyres out faster than I would have liked...
 :sad1:
But still give the extra flexibility for adjusting, to suit your needs... Or if you needed to tuck tyres in behind the arches  :pomppomp:
As Mike says they are a great mod !  :happy2:
« Last Edit: May 25, 2014, 12:11:55 am by scopes »
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #319 on: May 24, 2014, 10:26:29 pm »
It has to be another great set of mods !   :P  Peace of mind thing, even more so if you will be keeping your car !
Silver is the way !
Offline SurreyED30
« Reply #320 on: May 24, 2014, 10:27:00 pm »
Good to hear the car is feels much better handling wise mate and your happy with it  :smiley:
Would opyou not bother with the super pro ball joints then if your not after ' fitment ' and wanting a tighter front end? More importantly what have you replaced them with mate?
Jake
Offline SurreyED30
« Reply #321 on: May 24, 2014, 10:29:05 pm »
Yeah no half measures, just get it all the bushes done in one hit lol wanting stage 2+ with clutch first that's my main priority after my new suspension kit goes on....with extra bits that will be coming with it  :evilgrin:
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #322 on: May 24, 2014, 10:56:09 pm »
Jake
Cheers matey !  :driver:  Yes I would always want to have the SP Ball Joints now, it will allow the car to be setup that bit better, even more so if you wish to track your car...
Replaced with a new set ! Just trying to rule things out...  :innocent:
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #323 on: May 24, 2014, 10:59:36 pm »
Yes you have to prioritise ! Then getting it all done in one hit, will help keep the costs down  :happy2:
Silver is the way !
Offline SurreyED30
« Reply #324 on: May 24, 2014, 11:37:41 pm »
Can't wait to get every thing done and take her out for the test drive home with the new stiff/tighter set up
I'm looking forward to having the perfectly set up stage 2+ edition 30 by the end of the year....and tonnes of ££££ later  :signLOL: :rolleye: the list never ever ends does it  :P
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #325 on: May 24, 2014, 11:50:32 pm »
Well you kind of go in a circle, as you get the car how you would like it, then want to improve things  :rolleye:
Kinda crazy ! As you say the list never ends...
I find it really worth while, when everything is running in top condition !  The drive homes are always awesome, you never know what to expect  :jumpmove: :jumpmove:
« Last Edit: June 24, 2014, 10:02:08 am by scopes »
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
Re: ..Scopes Reflex Silver GTI with "Carbon Bits added"
« Reply #326 on: June 24, 2014, 10:23:59 am »
Not an update, but a small problem that is needing solved  :notworthy:
ARB Bushes, I have the whiteline ARB's fitted, but they seem to dry up, do the bushes need replacing or re-greased up, it's just i have tried re-greasing them, but before long the the dreaded squeaking comes back  :fighting:
Is there a certain type of grease to use?
Some better than others?
Can the bushes be replaced with a different type of bush?
Thanks in Advance !  :happy2:
Silver is the way !
Offline vRSAlex
  • -Receive: 253
« Reply #327 on: June 24, 2014, 01:22:58 pm »
Change to H&R bars  :party:
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #328 on: June 24, 2014, 01:35:47 pm »
 :mad:  No way !  :booty: You take trade in's ?  :signLOL:
Silver is the way !
Offline kylej1
« Reply #329 on: June 24, 2014, 07:54:40 pm »
How have I not seen this car before, the ap racing brakes are amazing aren't they, on the mobile so only got that far back, I've got them with r8 4pots and brake fade is a thing of the past, do you go to any of the gti NI shows, like castewellan or will u be at cruise for cancer?
