Author Topic: Cam follower  (Read 5740 times)
Offline dan930
  • -Receive: 56
Cam follower
« on: July 20, 2012, 01:40:27 pm »
Been advised that if I upgrade the hpfp it's best to change the cam follower too..is this true??
If yes where can I buy & part no please
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Re: Cam follower
« Reply #1 on: July 20, 2012, 01:41:30 pm »
Yes £26 from your dealer or parts counter
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
Re: Cam follower
« Reply #3 on: July 20, 2012, 02:05:11 pm »
here is the part number. In modded cars cam follower should be inspected and replaced regularly for peace of mind!
06D 109 309C
Paul
Re: Cam follower
« Reply #4 on: July 20, 2012, 02:23:20 pm »
06D 109 309C
Paul
As per the link above....  :booty:
Offline dan930
  • -Receive: 56
Re: Cam follower
« Reply #5 on: July 20, 2012, 02:42:16 pm »
Cheers everyone.. Are they easy to fit??
MK6 golfR dsg
AKS TUNED
R TECH custom map
Re: Cam follower
« Reply #6 on: July 20, 2012, 02:53:11 pm »
^^^^ as above and if I was getting it changed at the garage, how long would it take to change?
Offline edd666999
  • -Receive: 89
Re: Cam follower
« Reply #7 on: July 20, 2012, 03:02:06 pm »
took me going slowly an hour to take fuel pump off and put it back on. So if they change more than a hour they are having a giraffe
Re: Cam follower
« Reply #8 on: July 20, 2012, 03:06:18 pm »
If you are confident in removing the fuel pump (3 bolts and some hose clamps) then swapping the cam follower is very very straightforward
Just had a quick look for the guide on the forum but couldn't see it
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Cam follower
« Reply #9 on: July 20, 2012, 03:09:46 pm »
vRSAlex charged me 30mins labour to change my HPFP internals to Autotech ones and replace my cam follower
PLANS: Stage 2+
Offline edd666999
  • -Receive: 89
Re: Cam follower
« Reply #10 on: July 20, 2012, 03:17:22 pm »
unless you have the older pumps which both fuel lines are metal all the way upto the pump you have a very difficult bolt to remove.
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Cam follower
« Reply #11 on: July 20, 2012, 03:18:57 pm »
That's only AXXs tho, right?
PLANS: Stage 2+
  • -Receive: 453
Re: Cam follower
« Reply #12 on: July 20, 2012, 03:21:37 pm »
No!
My bwa engine had the dreaded banjo bolt.
Offline Mk5 GTian
  • -Receive: 37
Re: Cam follower
« Reply #13 on: July 20, 2012, 03:39:02 pm »
Wow, that is good! My tuner, Storm Developments, are doing that for me as well, but for £300.00 all in. Still a lot better than 750 for an APR pump plus fitting I guess.
Offline edd666999
  • -Receive: 89
Re: Cam follower
« Reply #14 on: July 20, 2012, 04:34:22 pm »
No!
did you look into getting all the fuel lines replaced with the newer ones at one point? didnt happen to record all the part numbers and or prices did you?
