Author Topic: Vibrating steering wheel  (Read 6057 times)
Offline dan930
  • -Receive: 56
« on: August 05, 2012, 02:24:30 am »
My steering wheel vibrates when going over 80mph(private road)
Can Anyone point to the right direction to what might the problem be??
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline jameelno1
  • TDI Power
Re: Vibrating steering wheel
« Reply #1 on: August 05, 2012, 02:50:49 am »
2 possible reasons for this could be that your wheels need balancing or wheel bearing
golf mk5 1.9 tdi
Offline dan930
  • -Receive: 56
« Reply #2 on: August 05, 2012, 02:57:30 am »
Just had new tires fitted to the car so I assume that the balancing be ok..if it was wheel bearing would it be noisy??
MK6 golfR dsg
AKS TUNED
R TECH custom map
vw55raz
« Reply #3 on: August 05, 2012, 03:44:38 am »
Wheel bearings would make a humming noise.
Have you checked the orientation of the tyre is correct. Normally an arrow Indicating forwards.
Rim might not be straight.
Air pressure too low in tyres.
Does it vibrate more when braking?
Offline Ree
« Reply #4 on: August 05, 2012, 07:44:16 am »
If this has started since the change of tyres it could be balancing !
Sometimes it could be a warped brake disc altho that is rare, however that would be more apprant with braking.
Offline Ben Smith
« Reply #5 on: August 05, 2012, 07:49:45 am »
Did the vibrating start since new tyres were fitted? 9 times out of 10 when we get cars with these symptoms it's just not been balanced properly.
  • -Receive: 453
« Reply #6 on: August 05, 2012, 08:21:27 am »
+1
Offline dan930
  • -Receive: 56
« Reply #7 on: August 05, 2012, 09:24:24 am »
+1
It doesn't vibrate when braking...& yes it started vibrating after I changed tires
MK6 golfR dsg
AKS TUNED
R TECH custom map
« Reply #8 on: August 05, 2012, 09:30:03 am »
Get them to rebalance. Sounds like you need to find a new tyre fitter ;-)
« Reply #9 on: August 05, 2012, 09:44:34 am »
Did some body shout meRich :signLOL:get them to check the balance again
Offline Baz300
« Reply #10 on: August 05, 2012, 11:04:31 am »
Agree!
For the sake of £20 I would get somewhere else to rebalance them and get a receipt to take to the place that fitted the tyres
Offline dan930
  • -Receive: 56
« Reply #11 on: August 05, 2012, 01:31:27 pm »
Agree!
Its getting me pi55ed off now cause I'm busy all day Monday & I've booked in for another custom remap at r-rech on Tuesday..if I don't get it sorted do you think it be ok on the dyno at r-tech??
MK6 golfR dsg
AKS TUNED
R TECH custom map
« Reply #12 on: August 05, 2012, 02:01:42 pm »
It will be ok on the dyno
Offline dan930
  • -Receive: 56
« Reply #13 on: August 05, 2012, 04:58:59 pm »
I'm glad that you said that as I was well paranoid with this issue..
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline dan930
  • -Receive: 56
« Reply #14 on: August 05, 2012, 07:01:59 pm »
Anybody else know for certain that it be ok on the dyno at r-tech??
MK6 golfR dsg
AKS TUNED
R TECH custom map
