Author Topic: Hurdy's Golf .:R.  (Read 957931 times)
Re: Hurdy's Golf .:R
« Reply #1980 on: January 07, 2014, 11:52:38 am »
Sy, I always have a target and mine is low 11's and a solid 500+ bhp. :happy2:
« Reply #1981 on: January 07, 2014, 11:55:50 am »
Decided not to de badge the front and so.........fitting!!!
The supplied screws to fit the bonnet to the hinges were too small and did not come with any washers
The pre-formed holes to accept the 4 rubber stops were all too small and had to be filed out and even then did not fit. In the end 4 Porsche 997 bonnet rubber stops were used as they are slightly smaller and a little softer.
The rubber strips on the bonnet that locate over the headlights have 5 plastic locators that go into 5 holes in the OEM bonnet. On the CF bonnet on the drivers side there were only 3 holes and 2 marks where the other two holes should have been.
The windscreen jets simply did not fit as the clips on the units are for thin sheet steel and not 3mm thick GRP plastic. This meant that they had to be secured as best possible and then glued.
The bonnet initially stuck up at one side, but after altering the seating and the bonnet housing for the catch it now sits just about right.
Pics....... :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #1982 on: January 07, 2014, 12:39:26 pm »
How come the change forom the LO4xx option?
« Reply #1983 on: January 07, 2014, 12:55:07 pm »
Because it wont run 500+...
Offline vRSAlex
  • -Receive: 253
« Reply #1984 on: January 07, 2014, 02:12:51 pm »
Sounds like 90% of the carbon bonnets I've had to fit over the years.  Even your silver one on the ED30 needed some fettling to get right.
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #1985 on: January 07, 2014, 02:22:47 pm »
 :drool: :drool: :drool: :drool:
Just lovely  :wink:  will you be fitting the bonnet catches to this one?
I have a weakness for carbon fibre bits  :rolleye:
Silver is the way !
« Reply #1986 on: January 07, 2014, 05:09:45 pm »
This. :wink: The L04XX would have been an option, but I have been given an opportunity that I cannot refuse  :innocent:
Oh, and I'm hoping to remove a few more kgs from the car too.
Possibly, but only if needed. :smiley:
« Reply #1987 on: January 07, 2014, 05:13:30 pm »
CF bonnet looks great.... much better with the badge too  :happy2:
« Reply #1988 on: January 07, 2014, 05:13:54 pm »
The silver one was a gazillion times better than this one.. :rolleye:
Offline Sunglasses Ron
« Reply #1989 on: January 07, 2014, 10:16:12 pm »
Soooo glad you kept the front badge John.. Without it I think you would made the car look a bit cheap (if that makes any sense?)..
« Reply #1990 on: January 08, 2014, 01:18:33 am »
looks bloody excellent-
« Reply #1991 on: January 08, 2014, 04:24:08 pm »
A few more piccies now the car is clean.   :drool:
Offline Wardy91-ed30
« Reply #1992 on: January 08, 2014, 04:43:37 pm »
Proper stealth :happy2: pro race look awesome on it too. Picking a new set up Saturday myself  :wink:
« Reply #1993 on: January 08, 2014, 04:50:45 pm »
The Pro Race wheels are excellent and tough as old boots. Save a decent weight over OEM wheels too. :happy2:
« Reply #1994 on: January 08, 2014, 05:01:56 pm »
Just what I'm after, light and make the car look aggresive :wink:
