Author Topic: Black rear badge  (Read 6182 times)
ReeceH13
Black rear badge
« on: September 03, 2012, 12:43:21 pm »
Dear all,
I have seen various posts re. the rear boot catch. I wondered what is the best way to get my badge black (glossy) Is it best to vynal wrap it? (MK5 GTI 2006) If so does anyone know if there are any places in Essex/London that would do this for me?
Thanks guys
Reece
AA
Re: Black rear badge
« Reply #1 on: September 03, 2012, 12:55:23 pm »
Plastikote or Rustoleum black spray paint  I've painted a few and had great results
 Make sure you use some 1000 or 800 grit and only paint in dry/warm conditions :happy2:
« Reply #2 on: September 03, 2012, 01:15:12 pm »
^^^^ as above, paint it!  :smiley:
 If you want to wrap it, it's fairly easy to do yourself. Get a piece of Gloss Black Vinyl from somewhere like eBay, take the badge of the boot handle and wrap. Place over badge, heat up with a hair dryer, pull into place and cut excess off. Can be fiddle as a small area and backwards and forwards with heating, stretching buy no point getting anyone else to to it. Have wrapped and painted them in the past, one below is the wrapped rear one on my Eddy.
Hope that helps  :happy2:
Offline Timi8888
« Reply #3 on: September 03, 2012, 02:08:42 pm »
Reckon it could be done by sanding the badge while it is on the car, then painting it black like that?
Sig to big.
« Reply #4 on: September 03, 2012, 02:25:46 pm »
^^^^ yes. Might look like a black hole with no definition but if your going for all black, don't see why not. Much easier to remove the whole unit and prep (sand), plastic prime, paint and laquear when it's off the car. It's 99% prep. If it looks like a DIY job it will look s**te.
The other thing  to remember is when spaying (if spraying it), it goes everywhere, you will really need to mask off the whole back of the car or you will be able to literally feel particals of spray all over the rear end.
ReeceH13
« Reply #5 on: September 03, 2012, 03:27:14 pm »
Thanks for all your help guys! Love this forum. MC71 loving the badge on your Eddy!! Will pluck up the courage and vynal wrap it at some point I think!
Offline Timi8888
« Reply #6 on: September 03, 2012, 03:27:55 pm »
How easy is it to remove the badge? and will it just be the chrome part that comes off?
Sig to big.
Offline gazon69
« Reply #7 on: September 03, 2012, 03:38:19 pm »
Here's mine, ebay £10
You will have to cut off the clips as they mount in different places, did mine with no fuss then just bonded it on. P.s i have taken it back off and it came off easily. At least doing it this way you will have your original to put back on if you ever decide to sell up, or as mentioned just wrap it.
« Last Edit: September 03, 2012, 03:45:14 pm by gazon69 »
« Reply #8 on: September 03, 2012, 03:42:54 pm »
If you have the 3D badge, simple. Open the boot release to 90 degrees and you should see a very small area In between the silver part and the black plastic part where a tool (I used a very strong flat bladed knife) can be inserted. Insert tool/knife and work around the edge from bottom to top on either side and bobs your uncle, the Silver VW emblem will pop off.
But if your referring to the whole unit, it's pretty simple, follow this from "Step 5"
http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
« Reply #9 on: September 03, 2012, 03:46:04 pm »
Ignore all my above posts and buy the one Gazon69 has from eBay, loads easier. Didn't know they sold em  :sad1: could have saved me hours!!
ReeceH13
« Reply #10 on: September 03, 2012, 03:52:26 pm »
Gazon,
Do you have the ebay link? I have read lots of threads that said the shop 'goingfast' sell ones that aren't compatible with the boot? Is this the one you bought?
Mine is an 06, so I am hoping its the two part badge, will save me a lot of time and effort...
Offline Timi8888
« Reply #11 on: September 03, 2012, 03:55:12 pm »
Gazon with this one, I have the 04 badge, can you just take off the badge, and stick this one onto it?
Sig to big.
« Reply #12 on: September 03, 2012, 04:00:08 pm »
^^^^ IIRC, no!
You can Buy the whole unit from eBay or on here in the "For Sale" section, they pop up (no pun intended) all the time for around £40-£50.
eBay
http://www.ebay.co.uk/itm/mk5-golf-3d-boot-handle-boot-pop-r32-gti-gt-golf-s-fits-all-models-/320972927797?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4abb7a3335#ht_1428wt_922
« Last Edit: September 03, 2012, 04:02:47 pm by MC71 »
« Reply #13 on: September 03, 2012, 04:15:44 pm »
Older version
Newer (3D) version
Mk6 version (will fit fine on Mk5)
Newer version with VW emblem removed
Rear of emblem (removed)
EBay Black one for sale
http://www.ebay.co.uk/itm/Golf-MK5-5-Black-VW-Boot-Rear-Hatch-Badge-Emblem-Logo-Polo-Lupo-GTI-TDI-R32-/221063697880?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item33786c55d8#ht_3538wt_804
Offline Timi8888
« Reply #14 on: September 03, 2012, 04:20:15 pm »
Not trying to piss you off MC71, but what does the old badge look like with the badge taken off?  :confused:
Sig to big.
