Author Topic: What's your next Mod? Talk to Me  (Read 4786 times)
Offline Mertyvw
« on: February 26, 2013, 10:58:46 am »
Talk to me peeps what is your next Mod on the list? Maybe i and other members can snatch some ideas.
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
Offline gigolo456
Re: What's your next Mod? Talk to Me
« Reply #1 on: February 26, 2013, 11:12:58 am »
THS side engine mounts, S3 intercooler, BSH throttle body pipe, and WMi kit...  :evilgrin:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: February 26, 2013, 11:27:19 am »
I have finished... BUT
996 T front brakes going on
superwhite LED's as per Monte's thread
Boot pop (paid for, on its way as we speak)
uprated speakers/amp
might consider an APR pump if a cheap one comes up
full correction (jay or nathan to the rescue!)
There all done (again..)
Offline Matto
  • -Receive: 116
« Reply #3 on: February 26, 2013, 11:46:08 am »
Full S3 brake setup, full Milltek system with Darkside Developments DPF delete pipe. Would like colour coded sideskirts and a RVC fitted aswell.
« Reply #4 on: February 26, 2013, 12:18:56 pm »
Fit NQS BBK
Fit R32 rear end
Fit Forge Shortshifter
Fit 42 Design shifter bushes
Buy
BCS Powervalve TBE 200 cell Prestige system
APR HPFP
Stage2 map
and probably a new clutch after that!  :sad1:
That will do for the next 6 months, daughters wedding to sort out!  :scared:
Offline skard
  • -Receive: 245
« Reply #5 on: February 26, 2013, 12:25:12 pm »
Next, I'll probably get a late model RNS510 in place of my current version.
I did have plans to go stage 2+ but I'll want a 5dr car in a year so the ED30 will stay as is until it's for sale.
I've already spent too much on it already, don't encourage me!
Offline marko
« Reply #6 on: February 26, 2013, 12:26:39 pm »
should have my complete folding mirror kit next week along with mfsw.
need to fit oem xenons i've had for over 8 months in my house and last thing will be a RVC installation
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #7 on: February 26, 2013, 01:09:44 pm »
You will love this Martin. Makes a huge difference for little outlay.
'07 Red manual
Offline Pirelli Paul
  • -Given: 64
« Reply #8 on: February 26, 2013, 01:13:30 pm »
Items listed below, just awaiting some recommendations and a quote back from Vagtech but a large majority of items have been purchased and awaiting my trip back to the UK on the 20th of April (Looking to arrange Vagtech to get the car a week before so that it will all be done for when I am back, some items may change slightly based on there feedback)
Powerflex 2 x (PFR85-508) Rear Tie Bar to Chassis Front Bush
Powerflex 2 x (PFR85-509) Rear Lower Spring Mount Outer
Powerflex 2 x (PFR85-510) Rear Lower Spring Mount Inner
Powerflex 2 x (PFR85-511) Rear Lower Link Outer Bush
Powerflex 2 x (PFR85-512) Rear Lower Link Inner Bush
Powerflex 2 x (PFR85-513) Rear Upper Link Outer Bush
Powerflex 2 x (PFR85-514) Rear Upper Link Inner Bush
NEUSPEED rear 25mm Sway Bar Clamp/Bushing Kit w/Grease Fitting
Whiteline Front Sway bar - link assembly heavy duty adjustable steel ball
Whiteline Heavy Duty Steering Rack Bushing
Volkswagen Golf 02Q Wavetrac 10.309.175WK LSD differential
ARP 10.498.02M 02M/02Q Wavetrac LSD bolt fitting kit
02Q Differential Bearing Kit
Performance Clutch Set + Single Mass Flywheel
VW VAG OEM Clutch release bearing 0A5141671F
Forge Hose Clamp Set
Forge Silicone Coolant Hose
Forge Twintercooler or THS or Eurojet Intercooler
Neuspeed 2.0T K04 Hi-Flow Turbo Discharge Kit Part Number: 48.02.70
Revo Integrated Throttle Pipe for VW Golf Mk5 2.0T FSI
Forge Alloy Radiator for MK5 Golf
Forge FMHTVAG-A Motorsport Alloy Coolant Tank
Neuspeed Power Pulley Kit 2.0 TSI 62.10.
Ignition Key Bezel VW
Volkswagen Motorsport Emblem
Pirelli 1 of 222 plaque
LED Lighting Interior Kit
LED Hyper White Foot Well Lights
LED Reverse light bulb = NEW Osram Series
LED Parking City Lights = Pair (No Error) x 2 Color 6000k
LED Door Warning Lights = Pair for 2 Doors with 3D LED (Hyper White)
Aluminum Look Glove Box Handle
Screen Protector for RCD510/ RNS510
Belkin Micro Auto Charger USB 1A
2 x Skoda Fabia Gas Struts                   6Y0 827 550 C
2 x Scirocco (Sprung) Pump stops        1K8 827 761 D
2 x Seat Leon Ball pins                          1J6 827 439 A
The inclusion of the above to the mods that have allready been done should pretty much wrap up the handling, performance (As far as stage 2 goes but may add the fuel pump etc. and go stage 2+) and cosmetics and then when this lot is done it’s the car audio.
Looking forwards to it  :happy2:
« Last Edit: February 26, 2013, 01:15:22 pm by Pirelli Paul »
Offline gigolo456
« Reply #9 on: February 26, 2013, 01:44:46 pm »
What's this shortshifter mod i hear about plse, does it smoothen gear changes?? :confused:
« Reply #10 on: February 26, 2013, 01:50:00 pm »
That's a great list Paul! :congrats: :congrats:
Have been researching the Wavetrac LSD's,. They do look very good.  Are these all the bits needed for a manual Paul, the Diff, fitting kit and bearing kit?
« Reply #11 on: February 26, 2013, 01:56:36 pm »
Have a look on this page from AwesomeGTI's site. Have a look into the Forge Adjustable Quick Shifter for VAG 6 Speed Models and the Forge Adjustable Side Short Shift VAG 6 Speed (personally not getting one of these) and the 42 Draft bushes for the Shifter Kit, you'll need to know your year as they differ.
~~ Clicky here ~~
  • -Given: 64
« Reply #12 on: February 26, 2013, 02:02:42 pm »
Yeah all parts are for the 6 speed manual, LSD, bolt kit and bearing etc.
The shifter kit just shortens the forward and backwards throw of the gear leaver and the draft 42 bushing kit is another hood complement to this, both together are a great mod to shorten and smooth the gear change and give it a more positive feel, in my opinion combined one of the best value mods you can do.
Cheers Paul
  • -Given: 64
« Reply #13 on: February 26, 2013, 02:05:45 pm »
The shifter kit I brought was I think Neuspeed and was not adjustable but was a well made item that fitted and worked well.
Offline Jettair
« Reply #14 on: February 26, 2013, 02:08:22 pm »
Fit my Altec plate mount after sourcing a new lower grille  :party:
