Author Topic: GFB DV+ OEM Diverter upgrade kit  (Read 130836 times)
Offline Mikeygtir
Re: GFB DV+ OEM Diverter upgrade kit
« Reply #105 on: October 24, 2013, 05:44:29 am »
i get the flutter on the oem valve.. if one of these was to make it more pronounced i'd be all over one of these! lol
Offline RedED30
  • -Given: 19
« Reply #106 on: October 24, 2013, 08:18:31 pm »
Both springs?
So no big change then?
Steve,
There has been reports that some K04 cars have been getting the fluttersound when you let off the throttle, like with the Forge spacer/ ITG open cone filter and standard diverter valve.
There is a bulletin on the GBE website (Link in this thread somewhere) that says you can achieve the flutter by removing the spring behind the brass plunger.
This will be at the sacrifice of throttle response. Yes there is a difference, i've noticed it more sub 2,800/3,000 rpm much more alive.
Dan
Revo Stage2 - With Linear Throttle
Revo DSG
BCS Turboback Powervalve - This is a must.
ITG Closed Intake.. wooosh
Here to enjoy and help, with a hint of sarcasm, please do not be offended
Offline SteveS
« Reply #107 on: October 24, 2013, 08:22:10 pm »
i get flutter now if i let it build boost then let off quick... but why anyone would want to create that sound i dont know...
hmm, tempted to buy one of these..
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline tommy2478
  • Instagram Tom_gti5
    • Photobucket Feed
« Reply #108 on: October 29, 2013, 09:42:19 pm »
I got a low end wine on mine as totally std car, now ive fitted an induction kit you get the whoosh when letting off the throttle under boost.
07 Mk5 Gti, Rear De-Wiper, Euro Fogs, Heko Wind deflectors, Pro Coils, GFB DV+
Offline Tim144
« Reply #109 on: October 31, 2013, 11:17:58 pm »
Fitted one to my K03 gti today... Pain in the arse to get to but is a brilliant fit non the less.
Looking to get it mapped in new year so will hopefully see good results with this fitted. Car certainly responds better now I have fitted the GFB DV+ Feels loads better in 4th gear pulling from low revs.
Offline bigeyd
  • -Receive: 31
« Reply #110 on: November 13, 2013, 10:47:54 am »
Fitted mine,not noticed a great deal but the dv was not split which I took off.
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #111 on: November 15, 2013, 09:28:33 am »
Guys got a set recently and wonder if I am missing a part?
I don't have the orange cylinder first on the left in the below pic
This is what I have
Paul
Offline bigeyd
  • -Receive: 31
« Reply #112 on: November 15, 2013, 10:54:34 am »
You will struggle without that Paul
Offline Tim144
« Reply #113 on: November 15, 2013, 12:59:57 pm »
Your missing the main plunger part.
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #114 on: November 15, 2013, 02:20:24 pm »
cheers guys!
Paul
Offline valle
« Reply #115 on: November 18, 2013, 06:46:12 pm »
would it make any sense , changing from forge  to this, on my mk5 gti???
« Last Edit: November 23, 2013, 05:36:06 pm by valle »
Offline th3_f15t
  • -Receive: 183
« Reply #116 on: November 23, 2013, 02:30:46 pm »
I've fitted this to my own GTI and it made a difference to the way the car pulls through the rev range, which has been amplified since getting a stage 1 remap and other bits bolted on. It's a good "fit and forget" part and a cheap way to really improve the engine (and ironically, a bit of fuel economy!)
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #117 on: January 02, 2014, 07:46:12 pm »
fitted that and car seems slower and achieved only 1.2 boost vs 1.6 I had normally. Also response is much slower than with stock so gonna put back the stock one. A bit disappointed to be frank
Paul
Offline Tim144
« Reply #118 on: January 02, 2014, 09:28:51 pm »
You seem to be running a K04 there has been an update on the internal spring contact your supplier.
« Reply #119 on: January 02, 2014, 09:47:17 pm »
Revision G is the only DV you need. No need for this OEM- (see what I did there??)  part
