Author Topic: MK6 gti airbag problem  (Read 14058 times)
Offline valle
Re: MK6 gti airbag problem
« Reply #15 on: September 18, 2013, 08:52:30 pm »
my friend took picture of the one we tried...lucky me...
so i need the airbag with ending L , N or AC , if i am correct??
Offline doylebros
  • -Receive: 310
« Reply #16 on: September 18, 2013, 08:52:59 pm »
you must use the multifunction version
if you don't it will be difficult to get the horn to work
What's your thoughts on the correct number Ed?
Offline doylebros
  • -Receive: 310
« Reply #17 on: September 18, 2013, 08:54:45 pm »
None multi function!
Offline valle
« Reply #18 on: September 18, 2013, 08:56:06 pm »
so there is different shape of the airbag of the multifunction and non one.
Offline doylebros
  • -Receive: 310
« Reply #19 on: September 18, 2013, 09:01:15 pm »
There must be a difference could be those lugs but see if Ed confirms it but I say you need 5K0 880 201 AC 81U
There are two listed on EBay under 5K0 880 201
5K0 880 201 F  is  multi functional dated 04/09 - 05/11
« Last Edit: September 18, 2013, 09:05:31 pm by doylebros »
Offline valle
« Reply #20 on: September 18, 2013, 09:02:27 pm »
Yes , with D and F...would this work ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #21 on: September 18, 2013, 09:05:43 pm »
The size is slightly bigger on a Non Multifunction, you can use them but a lot more pressure is required for the horn to work
Cluster and Key coding
Location Great Yarmouth
Offline valle
« Reply #22 on: September 18, 2013, 09:08:06 pm »
so i need part number:
5k0 880 201 AC   or
5k0 880 201 N     or
5k0 880 201 L
or ....?
has to be multifunction
Offline doylebros
  • -Receive: 310
« Reply #23 on: September 18, 2013, 09:11:10 pm »
F will work
Offline valle
« Reply #24 on: September 18, 2013, 09:14:50 pm »
Eddy, can u confirm that?
It's quite expensive , just to try ... :stupid:
Offline doylebros
  • -Receive: 310
« Reply #25 on: September 18, 2013, 09:18:21 pm »
The correct one on EBay is F since its multi functional but  D will work with hassle for horn operation.
Trouble multi functional  (free horn operation issue)
Finish in
F,G,L,N  or AC
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #26 on: September 18, 2013, 09:18:45 pm »
If you have a choice, buy the proper one
Offline valle
« Reply #27 on: September 18, 2013, 09:22:04 pm »
Ok, let's say , money doesn't metter.
The F is the correct one, will fit , multifunction will work, and horn will work correct????
I will buy the one , that has all that.
Offline doylebros
  • -Receive: 310
« Reply #28 on: September 18, 2013, 09:25:00 pm »
That's how I see it as well
Sent you an email with an attachment re-eBay item.
Offline valle
« Reply #29 on: September 19, 2013, 07:04:24 am »
Thanks for email.
So 5K0 880 201 F would be the correct one?
