Author Topic: door card help???  (Read 1867 times)
Offline golfgti10
door card help???
« on: September 27, 2013, 09:40:45 pm »
just took my door card off to fit the Passat buttons but can not get the lugs out, tried a coat hanger is there any where I can buy them new checked ebay cant find them as ill pull out the old and put in new
Offline skard
  • -Receive: 245
Re: door card help???
« Reply #1 on: September 27, 2013, 09:43:40 pm »
I use Y shaped plastic trim removers, cheap on ebay. You're best getting spare clips from a dealer though as some will probably break
Offline golfgti10
« Reply #2 on: September 27, 2013, 10:33:41 pm »
got a link to the tool also anywhere else I can buy apart from the dealer
« Reply #3 on: September 27, 2013, 10:48:09 pm »
Clips from the dealer, TPS, eBay or Boldsport and a few more no doubt. Cost peanuts for loads of them.
Clip remover......
~~ Clicky here ~~
Offline golfgti10
« Reply #4 on: September 27, 2013, 11:01:19 pm »
any of those can I order online and have posted from the uk
Offline skard
  • -Receive: 245
« Reply #5 on: September 28, 2013, 10:14:13 am »
These look like aftermarket door clips
http://bit.ly/16ytUlM
Something like this is cheap and useful
http://bit.ly/16HVciw
Or sacrifice an old fork to make a V with a bit tape on to prevent scraping your door
Offline sootpig
« Reply #6 on: September 28, 2013, 10:23:59 am »
There is no need to remove the cards :happy2:
 Those tools linked by SKARD are the way to go even when the ends become worn they can be fixed by a Stanley knife to give years of long service :happy2:
« Last Edit: September 28, 2013, 10:28:50 am by sootpig »
Offline skard
  • -Receive: 245
« Reply #7 on: September 28, 2013, 10:29:30 am »
Haven't done them, but fuel flap switch means the drivers side should come off?
Offline sootpig
« Reply #8 on: September 28, 2013, 10:37:59 am »
The fuel switch can be fitted without removing the card.I read about it on this forum so it must be true
 I did it myself  by creating a gap at the bottom of the door card and removing/refitting through the gap
 No broken bent clips as long as they are aligned before thumping the card back in place
« Reply #9 on: September 28, 2013, 11:25:08 am »
^^*^ PITA with the door card on. Its still best to take the door card off (or at least release it from the door) when fitting the Fuel Flap switch.
