Author Topic: Discs and pads  (Read 2910 times)
Offline cjchapman
Discs and pads
« on: February 12, 2014, 07:32:00 pm »
Hi guys,
Ive recently put my car through an MOT and one of the advisories was for me to change the discs and pads. I have a standard MK5 GTI brakes and I'm not looking to upgrade any time soon. With that in mind other than standard OEM discs and pads, do you have any recommendations?
I was thinking maybe standard discs with performance pads?
Thanks in advance!
Offline xjay1337
  • -Receive: 377
Re: Discs and pads
« Reply #1 on: February 12, 2014, 07:34:13 pm »
Standard discs with performance pads would be your best bet for performance vs cost   :happy2:
Offline cjchapman
Re: Discs and pads
« Reply #2 on: February 12, 2014, 08:26:49 pm »
Any particular performance pads?
Offline Sandbagsniper
Re: Discs and pads
« Reply #3 on: February 13, 2014, 12:34:56 pm »
DS2500's seem to get the vote on most fast road applications with a standard setup.
I am still surprised at how poor my standard brakes are for a hot hatch. The wifes clio 197 has Brembos as standard!
Offline Stevepd
  • -Given: 49
Re: Discs and pads
« Reply #4 on: February 13, 2014, 05:14:43 pm »
I've recent got our Golf and it's fitted with these DS2500 and it stops very well indeed. I just thought they were standard until I looked harder
Standard 5 Door Shadow blue.
Offline xjay1337
  • -Receive: 377
Re: Discs and pads
« Reply #5 on: February 13, 2014, 06:09:19 pm »
Another good thing to do is fit uprated brake fluid, ATE Superblue for example is not stupidly expensive and works well. In conjunction with better pads it would make braking a much more pleasant experience.
Offline Chris92
  • -Given: 33
Re: Discs and pads
« Reply #6 on: February 13, 2014, 06:24:17 pm »
Does just changing the pads to some uprated ones really make a noticeable differents?
Offline Madman1886
Re: Discs and pads
« Reply #7 on: February 13, 2014, 07:13:38 pm »
anyone know the best (and by best I mean cheapest :P  ) to get the afor mentioned pads???
Offline Stevepd
  • -Given: 49
Re: Discs and pads
« Reply #8 on: February 13, 2014, 07:18:26 pm »
I think they're on the bay for £25 each.
Offline cjchapman
Re: Discs and pads
« Reply #9 on: February 13, 2014, 10:15:23 pm »
Cheapest i can find for the front set is £140 ish. Anyone got any better links?
Re: Discs and pads
« Reply #10 on: February 13, 2014, 11:19:15 pm »
   Brake Disc Set (for 2 wheels - 2 x VENTED Disc) BREMBO 09.9772.10-Set (2 DISCS)
Free shipping on this item
   £81.80
   Brake Pad Set BREMBO P85075 / P 85 075 (for both wheels on 1 axle)-Brake Pad Set
Opie oils... works out at 95 quid for discs and pads once you apply the WAREHOUSE code!  :happy2:
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
Re: Discs and pads
« Reply #11 on: February 14, 2014, 12:32:59 pm »
Anyone know the best place to get the DS2500's?  Are they worth the extra $$$ in a stock set up with O.E discs?
 :wink:
Offline robern2
Re: Discs and pads
« Reply #12 on: February 14, 2014, 03:05:17 pm »
They are indeed. Might be worth dropping daveB a  message about discs.
Offline garrardrj
  • -Given: 76
  • -Receive: 42
Re: Discs and pads
« Reply #13 on: February 14, 2014, 05:26:25 pm »
   £81.80
Is this a reccomended discs/pads combo ? Need some at some stage and some rears , can you ring Opie oils and get the same deal ?
Re: Discs and pads
« Reply #14 on: February 14, 2014, 05:32:17 pm »
They will be great disc and pads for normal usage.
