Author Topic: Front plate magnets  (Read 4985 times)
Offline Adam-golf
  • Derv!
Front plate magnets
« on: March 05, 2014, 08:53:44 pm »
I'm currently having my front bumper sprayed so I have the front centre section off. I've smoothed the number plate holes so I'm looking to put magnets behind it to make my plate easy to un-attach.
I'm having a bit of trouble finding magnets that will be strong enough to hold it in place.
Does anybody know any where that would stick them, and if so which to go for.
Any advice welcome
Offline SI-R32
  • -Receive: 126
Re:
« Reply #1 on: March 05, 2014, 08:59:51 pm »
Get yourself some of these for the bumper and number plate, better if you have uk legal metal plate to bend slightly around the grill.
EBay
181327418684
Offline arris
Re: Front plate magnets
« Reply #2 on: March 05, 2014, 09:00:26 pm »
Im sure the ones im using are 20mm x 5mm
I have 10 fitted, 5 to the plate and 5 to the grill.
Cant find on my ebay who i bought them from but like these..
http://www.ebay.co.uk/itm/Pack-5-LARGE-and-STRONG-Neodymium-disk-magnets-20mm-dia-x-5mm-N35-grade-/141124751728?pt=LH_DefaultDomain_3&hash=item20dbb0d170
Offline Adam-golf
  • Derv!
« Reply #3 on: March 05, 2014, 09:06:44 pm »
Excatly what I was looking for!
What did you's use to stick them with? And what backing did you use on the plate to cover the magnets?
Offline SI-R32
  • -Receive: 126
Re:
« Reply #4 on: March 05, 2014, 09:09:10 pm »
Sticky backed black felt for the number plate and alrildite for sticking them
Offline arris
« Reply #5 on: March 05, 2014, 09:10:30 pm »
^ pretty much same as this.
Although i also used some foam,
When i did my original plate i cut circles in the foam where the magnets were then put another layer over the magnets to make it less noticeable.
Offline Adam-golf
  • Derv!
« Reply #6 on: March 05, 2014, 09:13:20 pm »
All ordered
Thanks guys  :happy2:
« Reply #7 on: March 05, 2014, 09:20:10 pm »
I always carry 2 plates, 1 with the magnets and 1 with double sided suction cups. Out of the 2 the sucker one causes less scratching on my uber expensive smoothed grill. I always carry the second one in the boot if/when I lose or mislay the other.
Suction...
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #8 on: March 06, 2014, 07:10:50 am »
I use suction cups too
Offline Adam-golf
  • Derv!
« Reply #9 on: March 06, 2014, 09:56:14 am »
Suction...
That's a very good idea! Where did you get the suckers from?
« Reply #10 on: March 06, 2014, 10:00:01 am »
eBay........
~~ Clicky here ~~
Offline Simon_2.0t
« Reply #11 on: March 06, 2014, 10:07:50 am »
Just ordered a shorter legal front plate and some magnets for mine  :happy2:
Offline Adam-golf
  • Derv!
« Reply #12 on: March 06, 2014, 10:25:27 am »
Think I'll put the suckers on my normal plate and buy some pressed for the magnets.
Did you get the same magnets as the ones mentioned above?
« Reply #13 on: March 06, 2014, 10:33:15 am »
^^^^ Get some N35 magnets. 20mm x 3mm is more than fine. Youll need at least 12 (I used 16), 6 or 8 for the plate and also 6 or 8 for the reverse side of the grill.
Offline SurreyED30
« Reply #14 on: March 06, 2014, 10:54:49 am »
might look into this, I think the front plate looks terrible  :confused:
