Author Topic: Anyone K04 a Mk6 GTI  (Read 24147 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Anyone K04 a Mk6 GTI
« Reply #15 on: July 14, 2014, 04:54:39 pm »
Just remember that all, EA888 engines (TSI in mk6 gti, also generation 3 (mk 7 GTI and R) are prone to oilstarvation should you take a turn with G power, so only straight line for those engines  :sad1:
http://www.accusump.com/accusump_units.html
it's a bit of a failure that the engine from start isn't built right  :confused:
Over the top mod list ;o)
Offline th3_f15t
  • -Receive: 183
« Reply #16 on: July 14, 2014, 05:45:11 pm »
So I'm justified in spending lots of cash on my mk5 GTI as its not going to starve itself or blow up? I like this thread.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #17 on: July 16, 2014, 01:00:36 am »
Yes, great info, cheers guys,  :notworthy:
So it really only needs the ko4 turbo with the DV relocation kit and a map, with it already mapped by Revo, 50 quid should update the map to stage 3?
Also get a Baffled Sump, to prevent oilstarvation ...
 :congrats: :congrats: :congrats: :congrats:
Silver is the way !
Offline mdmay
  • -Given: 38
Re:
« Reply #18 on: July 17, 2014, 06:02:47 pm »
The turbo needs to be modified as well.
Regards,
Mike
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #19 on: July 18, 2014, 12:45:05 pm »
They solved the cam follower design flaw of the TFSI though
« Reply #20 on: July 18, 2014, 01:05:29 pm »
My favourite engine from the MKV, MKVI and MKVII is still the EA113 TFSI CDL block. Very strong engine. There are a few tweaks you can do to make it even better, but if you are staying around the 400bhp mark then there is me real need for head or engine work; just bolt-ons will be enough.
  • -Given: 243
  • -Receive: 155
« Reply #21 on: July 18, 2014, 07:03:02 pm »
They did, and made the HPF system much stronger, still i would do as Hurdy and take a EA113 CDL engine over any other from the VAG. 500BHP possible from a stock engine and it can do corners as well  :wink:
Offline th3_f15t
  • -Receive: 183
« Reply #22 on: July 18, 2014, 07:42:22 pm »
Stupid question time: What cars come with CDL engines, Audi S3?
Offline Beddie
  • -Receive: 76
« Reply #23 on: July 18, 2014, 09:15:37 pm »
Golf R and ed35 is CDL too  :happy2:
Carbon Grey Edition 35 - Here
Offline greygti
« Reply #24 on: July 19, 2014, 09:33:02 am »
TTS
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #25 on: July 19, 2014, 10:35:46 pm »
Rocco R too!
Edition 30 BYD engine is 95% as good as the CDL  :drinking:
  • -Given: 243
  • -Receive: 155
« Reply #26 on: July 20, 2014, 09:31:15 am »
Rocco R too!
I'm not quite sure what the difference consists off? Hurdy, do you know?
Offline mdmay
  • -Given: 38
Re:
« Reply #27 on: July 20, 2014, 10:00:10 am »
I believe its the cams are different in the cdl to the byd
Regards,
Mike
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re:
« Reply #28 on: July 20, 2014, 11:16:14 am »
I'd heard the same. Aren't pistons, rods etc the same?
Offline mdmay
  • -Given: 38
« Reply #29 on: July 20, 2014, 11:32:29 am »
as far as i know yes. i previously had a cupra before the vrs and that had bwj engine which is the same minus the cams and a standard intercooler
Regards,
Mike
