Author Topic: Dans grey MK5 GTI. Prepping for VagTuner  (Read 276809 times)
dansmith180
Re: Dans grey MK5 GTI hybrid k03, tease time.
« Reply #435 on: January 30, 2016, 09:19:11 pm »
dansmith180
« Reply #436 on: January 30, 2016, 10:33:09 pm »
Only took a few photos today as I didn't want to get in Alex's way too much although I probably did anyway  :signLOL:
I don't even need to say it but great work from AKS as usual, sorted out quite a few niggly problems and all is working well at the moment.
Catch can didn't fit due to the boost tap so just used the washer relocation kit to tidy the bay up and will be selling the actual catch can kit.
Caddy rear calipers on standard 282mm discs and EBC yellow stuff pads to match the fronts.
Couple of pics of it on the ramp
Will get some better photos tomorrow after I've given it a proper clean inside and out.
Offline patpong_pete
« Reply #437 on: January 31, 2016, 12:55:53 am »
They looked good earlier dan.. good to see you.  :happy2:
How do they feel?
Thanks mate, you to.
I was still there until about 6:30  :signLOL:
But after an hour and a half drive its safe to say my neck hurts  :laugh:
Pedal feel is a bit more bitey than the ttrs kit (although could be partly the new pads), but they really do stop hard, also feels a bit more balanced with the caddy rears but need to do some 120+ stopping to really tell on that one.
Dan them brakes look like BBTC brakes how do they compare to your old TTRS set up please could u do a test or mini review thanks
dansmith180
« Reply #438 on: January 31, 2016, 10:05:56 am »
How do they feel?
Will do fella, give me a week or two to get some miles on them and really put them to work and I'll see how they compare  :evilgrin:
First impressions are they have less pedal movement which makes it a bit harder to modulate your braking but with a bit more finesse they're fine, they definitely have more overall stopping power, they're a kg or two lighter per side and they have waaaaaaay more clearance than the TTRS kit.
Offline xjay1337
  • -Receive: 377
« Reply #439 on: January 31, 2016, 10:37:03 am »
Yummy brakes :)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #440 on: January 31, 2016, 04:57:11 pm »
Really glad your happy with your new brakes! They look so much better how you had them painted. :drinking:
  • -Receive: 442
« Reply #441 on: January 31, 2016, 05:44:40 pm »
Ooh them front brakes,can't wait to get mine on when they arrive,be interested how you find them when they bed in
Offline th3_f15t
  • -Receive: 183
« Reply #442 on: January 31, 2016, 06:54:25 pm »
I need to pull my finger out and sort my front brakes out, and my suspension too... February will be a busy month for me!
dansmith180
« Reply #443 on: January 31, 2016, 07:09:52 pm »
Well pleased so far, when are yours due to arrive?
  • -Receive: 442
« Reply #444 on: January 31, 2016, 07:13:05 pm »
end of feb mate,already changed the rear disc and pads to the ebc ones
« Last Edit: January 31, 2016, 07:53:23 pm by maxitrol »
dansmith180
« Reply #445 on: January 31, 2016, 07:31:40 pm »
Which brakes are you going for again? I think you changed your mind about 4 times  :laugh:
Offline th3_f15t
  • -Receive: 183
« Reply #446 on: January 31, 2016, 07:46:58 pm »
Ah, not with the Golf R! I only ever wanted Porsche Cayenne fronts on it with 350mm single piece discs. I may swap to 2 piece discs at a later stage but for now I want it as a daily so I can't go too mad with expensive parts.
dansmith180
« Reply #447 on: February 01, 2016, 12:34:06 am »
Oh fair enough, I thought I remembered you eying up the VWR calipers for a while and then something else, maybe that was me  :laugh:. My mates got basically that same kit on his 470bhp S4, stops it very well  :happy2:
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #448 on: February 01, 2016, 06:31:58 pm »
Loving those brakes bud  :drool:
Would you reckon the caddy rears would complement s3 fronts as I would get them refurbished at the same time as the front?
dansmith180
« Reply #449 on: February 01, 2016, 07:59:33 pm »
Cheers fella, visually they're no different but they bring more balance to the brake bias as they have the same piston as the R32/ S3 calipers just on a smaller disc, but because of that they're about 6kg lighter overall than the R32 kit (I've read). Is definitely a nice touch and they really don't cost much.
