Author Topic: New south column boost pod  (Read 2086 times)
Offline Chris92
  • -Given: 33
« on: November 28, 2014, 10:10:05 pm »
Hi, does the new south steering column pod sit directly on top of the steering column trim or do you remove the standard plastic on top of the column and then place the new south on where the original plastic trim was?
Re: New south column boost pod
« Reply #1 on: November 28, 2014, 11:18:12 pm »
I believe you replace the existing trim
Offline Chris92
  • -Given: 33
Re: HELP. New south column boost pod
« Reply #2 on: November 29, 2014, 12:52:36 pm »
Right it all wired up etc but when I start it up the needle goes to 20 in hg on idle and when I rev it it's goes to 0 regardless of revs. So is this ok? Just don't want to screw the car back together to find I've got a fault. I haven't drive the car yet as it's in bits I've just reved it on the drive way
Offline v4rley
  • -Receive: 104
« Reply #3 on: November 29, 2014, 02:56:43 pm »
Yeah sounds right, think it will only boost under load! Get itnput back together and go for a drive  :driver:
Offline Chris92
  • -Given: 33
« Reply #4 on: November 29, 2014, 03:09:23 pm »
Just got back from a drive, peaks at 12-13 then holds at 10psi, I'm sure I've read on here it should be 22psi? I'm totally stock minus the boost gauge. Does my figures sound right?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: November 29, 2014, 03:18:39 pm »
Sounds correct for a stock gti. See log below.
05 | Tornado Red | DSG
