Author Topic: Xenons shaking when hitting bumps  (Read 4090 times)
Offline K9
  • VW LifeStyle
« on: November 30, 2014, 07:35:42 pm »
hey, how can i prevent the xenons to shake when hitting bumps? i mean some aggresive bumps hard, can i put some plastic inbetween somewhere to prevent it or some other tips? as it's annoying me  :sad1:
Offline doylebros
  • -Receive: 310
Re: Xenons shaking when hitting bumps
« Reply #1 on: November 30, 2014, 07:38:03 pm »
Did you fit the self levellers in your install?
Offline K9
  • VW LifeStyle
« Reply #2 on: November 30, 2014, 07:41:22 pm »
nope, will be adding auto leveling in the summer. right now without any highadjustings.
Offline doylebros
  • -Receive: 310
« Reply #3 on: November 30, 2014, 07:51:43 pm »
Have you checked the rear of the housing to make sure the bulbs are still latched and seated properly and that the projectors aren't loose inside?
Also it's possible that it's flashing because of a coding issue and working the shutter for the Bi-xenon?
Offline K9
  • VW LifeStyle
« Reply #4 on: November 30, 2014, 08:14:53 pm »
got the bi-xenon shutter to work about 1h ago. and drove yesturday when i noticed they are shaking on hard bumps only.
how can i secure the projector if it's loose? any screws? will check the bulbs tomorrow when i'm getting yellow h7 55w for highbeam and led sidelights.
Offline doylebros
  • -Receive: 310
« Reply #5 on: November 30, 2014, 08:23:58 pm »
Offline K9
  • VW LifeStyle
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #7 on: December 01, 2014, 12:06:07 am »
Are you sure you don't have damaged headlights? The interior mechanism shouldn't be loose when you shake the headlight.
Offline K9
  • VW LifeStyle
« Reply #8 on: December 01, 2014, 08:19:02 am »
nah they aint loose. tried that  :scared:
edit: the headlight moves just a tiny little when pushing it with your hand up and down. can it be prevented with something?
« Last Edit: December 01, 2014, 08:20:42 am by K9 »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #9 on: December 01, 2014, 08:31:11 am »
Is it the headlight you had to replace all 3 fixing mounts by any chance?
Offline K9
  • VW LifeStyle
« Reply #10 on: December 01, 2014, 08:37:16 am »
yeah it's the headlight. any chanses to steady it up somwhow?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #11 on: December 01, 2014, 11:55:16 am »
Well IMO thats where you start, i'd pull the light out and check the mounting points, sounds like the install of the mounts needs looking at?
Offline K9
  • VW LifeStyle
« Reply #12 on: December 01, 2014, 04:13:18 pm »
is there a way to make them more solid? the top one what is flexing
